SEN0519 Connector type?
userHead Bright1337 2026-04-08 01:35:04 626 Views1 Replies
Is the connector a standard m12 4 pin or is it something proprietary?
2026-04-08 10:34:29
The URM15 RS485 ultrasonic sensor adopts a 4-core cable design. It is not equipped with a standard M12 4-pin circular connector, so it cannot be directly connected with a standard M12 4-pin plug. Please wire it directly according to the specified wire sequence.
WIKI link:  URM15 - 75KHZ Ultrasonic Sensor (30~500cm, RS485) | DFRobot Wiki
userHeadPic Yx
