General HUSKYLENS
Huskylens AI camera V1 with ESP32 board
userHead Ahmad.bin muhamad 2026-04-08 23:39:55 1493 Views5 Replies
hi.. need help.. Huskylens Ai camera can work with ESP32 board?
if yes.. any example basic coding ?
before this i use arduino Mega with Husklylens all work fine..
when try use with ESP32 board.. example coding (from huskylens library) Error compiling..
thanks
2026-05-26 09:54:07
Since Huskylens2 is in 5V and ESp32 is in 3V3, is it possible to directly connect the RX and TX pins between them?
userHeadPic Shaifol.Ifrad
Yx wrote:
Direct connection of RX and TX is acceptable. However, please power Huskylens 2 separately to avoid insufficient power. You can use an extra Type‑C cable to connect its Type‑C port to a power source.
2026-05-26 11:37:02
2026-04-09 21:56:58
yes.. it work.. thanks Yx..
userHeadPic Ahmad.bin muhamad
2026-04-09 10:26:03
Hi! Yes, the HuskyLens AI camera is fully compatible with ESP32 boards!
I tested the library example HUSKYLENS_I2C.ino with ESP32 and encountered this compilation error:
E:\auduino\libraries\HUSKYLENS\HuskyLensProtocolCore.c:135:12: error: returning 'uint8_t ()[128]' {aka 'unsigned char ()[128]'} from a function with incompatible return type 'uint8_t *' {aka 'unsigned char *'} [-Wincompatible-pointer-types]
135 | return &send_buffer;
exit status 1
Here's the fix: Locate the HuskyLensProtocolCore.c file, change line 135 from “return &send_buffer; ” to “return send_buffer; ” , save the file and recompile.
userHeadPic Yx
Ahmad.bin muhamad wrote:
thanks for replay.. very appreciated.
let me try edit that file and update the result.
thanks
2026-04-09 21:43:07
