Is the sensor completely submersible?
Cyn 2026-04-10 10:08:22 670 Views1 Replies Is the sensor completely submersible?
2026-04-10 12:09:45
Cyn
Yes. The integrated probe and housing carry an IP68 waterproof rating. It is designed for continuous submersion.However, the top wire conduit connection should be sealed with Teflon tape if the entire cable assembly is subjectedto deep-water pressure.
Cyn
