The following code throws multiple errors.
williampretty 2026-04-14 03:09:05 782 Views2 Replies The following code throws multiple errors.
Has anyone successfully compiled a program that uses target tracking ?
--------------------- Code -----------------------------------------
#include "DFRobot_HuskylensV2.h"
#include "DFMobile.h"
#include "Wire.h"
// Create object
HuskylensV2 huskylens;
DFMobile Robot(4, 5, 7, 6); // Motor control pins for Romeo
int centerThreshold = 50; // Tolerance for steering
Wire.begin();
Serial.begin(115200);
while (!huskylens.begin(Wire)) {
Serial.println("Begin HUSKYLENS failed!");
delay(100);
huskylens.switchAlgorithm(ALGORITHM_OBJECT_TRACKING); // Switch to Object Tracking
if (huskylens.available()) {
HUSKYLENSResult result = huskylens.read();
// Check if object is left, right, or center
if (Result.xCenter < (160 - centerThreshold)) {
// Object on left: Turn Left
Robot.Speed(-150, 150);
} else if (Result.xCenter > (160 + centerThreshold)) {
// Object on right: Turn Right
Robot.Speed(150, -150);
} else {
// Object centered: Move Forward
Robot.Speed(200, 200);
} else {
// No object found: Stop
Robot.Speed(0, 0);
Hi there! I noticed you only mentioned one compilation error in your previous thread, and I've already shared the fix for that. For your current issue with multiple errors, I highly recommend testing the official target tracking example code directly—it's fully tested and ready to compile!
Yx Thanks for your continued help and patience.
Where can I download the “official target tracking code” ?
GitHub link: https://github.com/DFRobot/DFRobot_HuskylensV2 doesn't appear to have the actual program code.
