Simple target tracking code not working
userHead williampretty 2026-04-22 23:16:42 862 Views1 Replies
So now that I have the simple target tracking code working it is time to write some code that causes the robot to track the object outlined in the blue box.
The following code generates the following error:
error: expected primary-expression before '.' token
    if (Result.xCenter < (160 - centerThreshold)) {
----------- Code ------------
#include "DFRobot_HuskylensV2.h"
#include "DFMobile.h"
#include "Wire.h"
// Create object
HuskylensV2 huskylens;
DFMobile Robot(4, 5, 7, 6); // Motor control pins for Romeo
int centerThreshold = 50; // Tolerance for steering
  Wire.begin();
  Serial.begin(9600);
  while (!huskylens.begin(Wire)) {
    Serial.println("Begin HUSKYLENS failed!");
    delay(100);
 Serial.print("Switching to tracking mode");
  // Switch to Object Tracking mode
  huskylens.switchAlgorithm(ALGORITHM_OBJECT_TRACKING);
   // Request results from the sensor
      if (huskylens.available(ALGORITHM_OBJECT_TRACKING)) {
    huskylens.getResult(ALGORITHM_OBJECT_TRACKING);
    // Check if object is left, right, or center
      // Object on left: Turn Left
      Robot.Speed(-150, 150);
    } else if (Result.xCenter > (160 + centerThreshold)) {
      // Object on right: Turn Right
      Robot.Speed(150, -150);
    } else {
      // Object centered: Move Forward
      Robot.Speed(200, 200);
   else {
    // No object found: Stop
    Robot.Speed(0, 0);
2026-04-29 17:36:45
It appears to be an I2C bus issue; we will try to reproduce and resolve the problem.
userHeadPic Yeez_B
