Difficulty syncing ESP32 data with mobile script managers
Mia.orlov 2026-05-06 03:54:31 21 Views0 Replies Hey everyone,
I've been working on a project involving an ESP32 and a custom-built sensor array, trying to get the real-time data to display correctly on my mobile device. I usually run a few background scripts to handle the incoming data packets, but I've hit a bit of a wall.
Lately, I’ve been trying to see if I can integrate my data stream through the arceus x executor environment to see if the convo between the hardware and the script handles the latency any better. However, I’m getting constant "Socket Timeout" errors whenever the baud rate is set above 9600.
I'm also seeing a weird issue where the mobile app UI freezes the moment the ESP32 starts sending high-frequency bursts. Has anyone here had experience troubleshooting serial-to-mobile data pipelines while running external script executors? I'm trying to figure out if the bottleneck is in my buffer management on the ESP32 side, or if the mobile OS is just killing the background process because of the power draw.
If anyone has managed to get a stable connection for a similar setup, I'd love to hear how you configured your manifest or if there's a specific library you'd recommend for better stability!
Best
