Problems to controll M0601/FIT1042
userHead Ulrich.Seidel 2026-05-13 18:32:47 591 Views1 Replies
I have an Arduino UNO R4 WIFI.
Mounted on it is the RS485 Shield v1.0.
Motor: FIT1042 / M0601
Orange -> B
White -> A
Brown -> Ground
The following code is running on the Arduino.
#include <Arduino.h>
#define RS485_DIR_PIN 2
// SEND FRAME
void sendFrame(uint8_t *data, int len)
   digitalWrite(RS485_DIR_PIN, HIGH);
   delay(5);
   Serial1.write(data, len);
   Serial1.flush();
   delay(5);
   digitalWrite(RS485_DIR_PIN, LOW);
// PRINT HEX BYTE
void printHex(uint8_t b)
   Serial.print("0x");
   if (b < 16)
       Serial.print("0");
   Serial.print(b, HEX);
   Serial.print(" ");
// READ RESPONSE
void readResponse()
   unsigned long start = millis();
   while (millis() - start < 300)
       while (Serial1.available())
           uint8_t b = Serial1.read();
           printHex(b);
   Serial.println();
// SETUP
   pinMode(RS485_DIR_PIN, OUTPUT);
   // Empfangsmodus
   Serial.begin(115200);
   Serial1.begin(115200);
   delay(3000);
   Serial.println();
   Serial.println("=== M0601 SIMPLE SPEED TEST ===");
// LOOP
   // Speed Command
   uint8_t frame[10] =
       0x01, // ID
       0x64, // CMD Speed
       0x00,
       0x64, // Speed = 100
       0x00,
       0x00,
       0x00,
       0x00,
       0x00,
       0xC9  // Beispiel Checksum
   // PRINT TX
   Serial.print("TX: ");
   for (int i = 0; i < 10; i++)
       printHex(frame[i]);
   Serial.println();
   // SEND
   sendFrame(frame, 10);
   // PRINT RX
   Serial.print("RX: ");
   readResponse();
   delay(2000);
i tried:
- Swapped A and B
- Swapped IO pins 1 and 2
- Swapped the black and brown wires
- Ensured the motor and Arduino share a common ground
- Applied a steady 18-volt supply to the motor
- Verified that the motor exhibits resistance once power is applied
- Tested both a different motor and a different Shield
Can somebody help me plz ?
Is there a libary.h for the motor?
thx
2026-05-13 18:36:47
The TXD LED also flashes every 2 seconds.
The RXD LED flashes only once—when I power up the motor.
In the Serial Monitor, I see "0xAA 0x55 0xFF" being returned by the motor upon power-up.
userHeadPic Ulrich.Seidel
