Beetle ESP32-C6 max mA per pin?
userHead Noël 2026-05-16 01:51:16 806 Views1 Replies
I need to turn on/off a NEO-9 GPS (when the ESP goes into deep sleep, turn off the GPS too).
At the moment, I am using a MOSFET (an IRLML6402) with the gate set high so the drain powers the GPS (source -> drain).
As the pin can handle 20 mA, I was wondering if I could tie multiple pins together to power the NEO-9 directly and bypass the MOSFET.
I need about 43 mA.
Any help appreciated.
Noel
2026-06-03 09:52:30
Hi there,
It’s not safe to parallel multiple ESP GPIO pins to power your NEO-9 (43mA). GPIOs are signal ports, current can’t split evenly and will burnout one pin easily, plus output voltage will sag under load.
userHeadPic Yx
