viewer software error, 64×8 Matrix DTOF 3D Distance Sensor, wy860-lib16.dll
aldras 2026-05-20 10:38:53 681 Views1 Replies I am attempting to use the software at the following link:
SEN0682-Host Computer Debugging Software-V1.0.zip
I am using Windows 11 on ARM and get this following DLL error, same error with Windows 7 on x64.
Can not find the procedure entry point, can not find wy860-lib16.dll.
Where may I find this dynamic library file?
I can not find this file, and would like to use the above software to verify the detection area and range of the sensor.
I will try to upload an image of the error.
Is there any suggestion or recommendation or another software to use?
Thanks,
Allan
I checked the current software package again, and there is no separate wy860-lib16.dll file included. However, the software can start and run normally on a standard x64 Windows 11 PC.
So this issue may not be caused by a missing file in the package. It is more likely related to system compatibility or runtime dependencies. ARM-based Windows 11 may not be fully compatible with some x64 PC software, and Windows 7 may also have similar issues due to an older system environment or missing runtime libraries.
Suggested steps:
1. Test the software on a standard x64 Windows 10/11 PC;
2. Fully extract the software package and run it directly from the original folder;
3. Install or repair Microsoft Visual C++ Redistributable 2015–2022 x64;
Yx
