TEL0150 Driver
userHead Jacob.Sigmund 2026-05-22 03:14:53 625 Views1 Replies
Is there a location to find and download the Driver needed for the DFrobot? Need this when I am trying to use it
2026-06-02 18:04:49
Hi, for TEL0150, the “driver” usually means the computer-side USB serial driver. A separate DFRobot driver or library is usually not needed.
When using USB Type-C, it should appear as a USB serial device. Open the serial port with a terminal tool, then send AT/SLCAN commands directly.
If using UART with Arduino, ESP32, or another controller, it is also controlled by serial commands. The default UART baud rate is 115200bps.
If no serial port appears after plugging it in, look for the USB serial driver that matches your operating system, such as Windows, macOS, or Linux.
userHeadPic Yx
