GravityHow to select
Digital IR transmitter module source and wavelength
userHead Jeffrey.White 2026-05-24 10:05:42 672 Views1 Replies
Gravity: Digital IR Transmitter Module
SKU: DFR0095
Is the emitter an LED or a laser?
What is the wavelength?
2026-06-01 15:43:46
Hi, it is an infrared LED emitter, not a laser.
According to the DFRobot wiki, the IR wavelength range is 850-940 nm. You can find it in the DFR0095 wiki specs here: https://wiki.dfrobot.com/dfr0095/#tech_specs
userHeadPic Yx
