Gravity: Active Isolated RS485 to UART Signal Adapter Module? or it is just an optional?
magnacita 2026-06-29 20:41:46 564 Views1 Replies Hi, should I use Gravity: Active Isolated RS485 to UART Signal Adapter Module as a module for RS485 Fluorescence Dissolved Oxygen Sensor (Freshwater)? or it is just an optional?
2026-06-30 09:54:37
Yx
You need an RS485-to-UART converter (such as the Gravity: Active Isolated RS485 to UART Signal Adapter Module) to communicate with a UART-based controller like an Arduino. The DFRobot module is recommended, but any compatible RS485-to-UART converter can also be used.
Yx
