EC Signal Conversion Board (SEN0451) Getting Excessively Hot — Possible Hardware Defect?
rstevens009 2026-07-04 00:47:06 615 Views1 Replies Title: EC Signal Conversion Board (SEN0451) Getting Excessively Hot — Possible Hardware Defect?
Hello DFRobot Community,
I am hoping someone here can help me diagnose an issue with the EC Signal Conversion Board that came with my Gravity: Industrial Analog EC / Electrical Conductivity Meter Kit (SKU: SEN0451).
THE ISSUE:
The EC Signal Conversion Board becomes excessively hot within 30 seconds of powering up — too hot to hold my finger on. This happens consistently every time I power it up.
MY SETUP:
- Microcontroller: Freenove ESP32 WROOM on a Freenove Breakout Board
- Power supply to EC board: 3.3V regulated output from the breakout board (within the specified 3.3-5V range)
- EC probe: The probe included with the SEN0451 kit, submerged in hydroponic nutrient solution
- S+ and S- wires correctly connected to their respective terminals on the board
- Signal (A) wire connected to GPIO35 on the ESP32
DIAGNOSTIC STEPS I HAVE ALREADY TAKEN:
1. Verified power supply is 3.3V with a multimeter — confirmed correct
2. Verified S+ and S- are not shorted together — confirmed no short
3. Visually inspected the board — no burn marks, discoloration, or burnt smell
4. Isolated the EC board completely from all other components
5. Tested with only the EC board connected, ESP32 powered via USB only
6. EC probe submerged in water during testing
7. Board still gets excessively hot within 30 seconds under these isolated conditions
MY READINGS BEFORE THE OVERHEATING ISSUE:
When the board was first installed, the EC readings were working and showing values around 2350 µS/cm in my hydroponic nutrient solution. The board started overheating during a rewiring session where I was reconfiguring connections to a new breakout board.
MY QUESTIONS:
1. Is some warmth normal for the EC Signal Conversion Board during operation, and if so, how warm is acceptable?
2. Could operating at the upper end of the EC range (~2350 µS/cm) cause excessive heat?
3. Has anyone else experienced this overheating issue with the SEN0451 EC board?
4. Is there any way to test whether the board has sustained internal damage?
5. Are there any diagnostic steps I may have missed?
Any help or suggestions would be greatly appreciated. I have already emailed DFRobot support, but have not received a reply yet.
Thank you!
That amount of heat is not normal.
To confirm, you could measure the current drawn from 3.3 V, check resistance between VCC and GND with power off, verify the cable pin order/polarity, and test the board with no probe and no signal wire connected. If it still heats quickly, the board is very likely damaged and should be replaced.
Yx
