tel0157 gss gps
jamess2345 2026-07-17 05:43:40 483 Views1 Replies I am using the tl0157 gps in urat mode. I can not get it to return getSog() and getCog() they remain at 0 while moving. It does return Long and Lat. However N W are reversed. Below is my code
TEL0157 UART Simple Road Test
GPS wiring:
5V -> VCC
GND -> GND
GPIO43 ESP32 TX -> TEL0157 C/R
GPIO44 ESP32 RX <- TEL0157 D/T
TEL0157 selector switch: UART
#include "DFRobot_GNSS.h"
#include <HardwareSerial.h>
static const uint32_t GPS_BAUD = 9600;
static const uint8_t GPS_RX_PIN = 44;
static const uint8_t GPS_TX_PIN = 43;
HardwareSerial GPSSerial(2);
DFRobot_GNSS_UART gnss(&GPSSerial, GPS_BAUD, GPS_RX_PIN, GPS_TX_PIN);
unsigned long previousPositionPrint = 0;
Serial.begin(115200);
delay(2000);
Serial.println();
Serial.println("TEL0157 UART SIMPLE ROAD TEST");
Serial.println("ESP32 RX GPIO44 <- GPS D/T");
Serial.println("ESP32 TX GPIO43 -> GPS C/R");
Serial.println("TEL0157 switch must be set to UART");
while (!gnss.begin())
Serial.println("TEL0157 NOT DETECTED");
delay(1000);
Serial.println("TEL0157 detected");
gnss.enablePower();
delay(100);
gnss.setGnss(eGPS_BeiDou_GLONASS);
delay(100);
gnss.setRgbOn();
Serial.println("Take the unit outdoors and drive above 5 MPH.");
double sogKnots = gnss.getSog();
double speedMPH = sogKnots * 1.15078;
Serial.println("------------------------------------");
Serial.print("SOG knots: ");
Serial.println(sogKnots, 4);
Serial.print("Speed MPH: ");
Serial.println(speedMPH, 2);
if (millis() - previousPositionPrint >= 5000)
previousPositionPrint = millis();
uint8_t satellites = gnss.getNumSatUsed();
sLonLat_t latitude = gnss.getLat();
sLonLat_t longitude = gnss.getLon();
double course = gnss.getCog();
Serial.print("Satellites used: ");
Serial.println(satellites);
Serial.print("Latitude: ");
Serial.print(latitude.latitudeDegree, 7);
Serial.println(" N");
Serial.print("Longitude: ");
Serial.print(longitude.lonitudeDegree, 7);
Serial.println(" W");
Serial.println((char)longitude.lonDirection);
Serial.print("Course: ");
Serial.println(course, 2);
delay(1000);
And below here is the serial monitor while driving. Longitude: 92.8673290 W
N
Course: 0.00
SOG knots: 0.0000
Speed MPH: 0.00
SOG knots: 0.0000
Speed MPH: 0.00
SOG knots: 0.0000
Speed MPH: 0.00
Satellites used: 8
Latitude: 44.9985172 N
Longitude: 92.8679000 W
N
I am using the following PCB micro esp32 https://docs.waveshare.com/ESP32-S3-LCD-2.8C any help you can provide would be appreciated
Your pin mapping looks right: on the ESP32-S3-LCD-2.8C, TXD is GPIO43 and RXD is GPIO44, so TEL0157 D/T(TX) -> GPIO44 RX and C/R(RX) -> GPIO43 TX is correct. One important board detail: Waveshare says the 4-pin UART header is disabled when the USB-to-UART Type-C port is connected, so test with that port disconnected if possible.
For the N/W issue, don’t hard-code the hemisphere text. Print the direction fields returned by the library:
Serial.print(" ");
Serial.println((char)latitude.latDirection);
Serial.print(" ");
At your location, the expected result is N for latitude and W for longitude. If longitude.lonDirection still prints N, please try the stock DFRobot TEL0157 UART example and share the installed DFRobot_GNSS library version.
For getSog() and getCog(), the library reports SOG in knots and COG in degrees. Since latitude/longitude and satellites are updating, the next check is whether the module’s raw GNSS data contains nonzero speed/course while moving. If raw $GNRMC / $GNVTG also shows zero or blank speed/course, the module is reporting zero. If raw data has nonzero speed/course but getSog() / getCog() stay at 0, that points to a library parsing/register issue.
Yx
.jpg)
