Using full Firebeetle ESP32-E flash in Platformio
userHead Rob.St 2026-07-27 00:31:43 264 Views1 Replies
I have the DRF1139 ESP32-E modules, which have 16MByte flash, and have been successfully using them in Platformio using default 4Mbyte settings.
I now need more SPIFFS space, so have been trying to use alternate partition tables such as the default 16MB csv from
https://github.com/espressif/arduino-esp32/tree/master/tools/partitions
Although upload seems to work, and the ESP32Connect tool seems to show the new partitions have been established, the ESP32 goes into continuous reboots.
I have successfully run a non-4MB Blink sketch in Arduino IDE.
My guess is that PlatformIO still thinks there is only 4Mbyte of Flash.
In Platformio's list of available boards, there is only one option for DFRobot Firebeetle 2 ESP32-E, and it is 4MB.
I have been unable for find a platformio option to change this.
My board config:
[env:dfrobot_firebeetle2_esp32e]
platform = espressif32
board = dfrobot_firebeetle2_esp32e
board_build.mcu = esp32
board_build.f_cpu = 240000000L
framework = arduino
Any assistance would be appreciated, thanks.
Rob
2026-07-29 14:01:05
You need to tell PlatformIO the flash size — the board definition defaults to 4MB, so using a 16MB partition table on top of that causes the boot loop.
Add these to your platformio.ini:
board_upload.flash_size = 16MB
board_build.flash_size = 16MB
board_build.partitions = default_16MB.csv
Then do a full erase and re-upload. Also double-check that ESP.getFlashChipSize() returns 16777216 once it's working.
Hope this helps!
userHeadPic Jason.Miao
