Choosing the Right Card Edge Connector for PCB Projects
Nazar.Electronics 2026-07-27 12:57:42 24 Views0 Replies Hi everyone,
I'm currently working on a custom PCB project that requires a reliable card edge connector. While comparing different connector types, I noticed that selecting the correct pitch, number of contacts, mounting style, and current rating can significantly affect both performance and long-term reliability.
For anyone designing embedded systems, industrial electronics, or communication hardware, here are a few points worth considering:
https://www.unikeyic.com/category/card-edge-connectors.html
Match the connector pitch with your PCB layout.Check the current and voltage ratings before finalising the design.Consider gold-plated contacts if the connector will be inserted and removed frequently.Verify compatibility with your board thickness and application environment.
While researching available options, I found a well-organised category listing different types of card edge connectors that made comparison easier: Card Edge Connectors Has anyone here used card edge connectors in industrial or embedded projects? I'd be interested to know which specifications you consider most important when selecting one.
Thanks!
