How to selectGravity
dfrobot voice recognition UART wakeup
userHead cdb0ewm 2026-08-01 23:34:32 413 Views1 Replies
I'm trying to get this module to wake up - blue light - and stay on once the XIAO EP32 C3 is powered up. I've tried several suggestions from other sites but no luck.
`#include "DFRobot_DF2301Q.h"
#include <esp_now.h>
#include <WiFi.h>
uint8_t broadcastAddress[] = { 0x14, 0x08, 0x08, 0xa5, 0xd7, 0x68 };
DFRobot_DF2301Q_UART DF2301Q(/*hardSerial =*/&Serial1, /*rx =*/D7, /*tx =*/D6);
#define Rgt D0
#define Lft D1
int RbuttonPin = D9;
int RbuttonPushCounter = 0;  // counter for the number of button presses
int RbuttonState = 0;        // current state of the button
int RlastButtonState = 0;
int LbuttonPin = 29;
int LbuttonPushCounter = 0;  // counter for the number of button presses
int LbuttonState = 0;        // current state of the button
int LlastButtonState = 0;
typedef struct struct_message {
  int b;
} struct_message;
struct_message myData;
esp_now_peer_info_t peerInfo;
DFRobot_DF2301Q_I2C asr;
void OnDataSent(const esp_now_send_info_t *tx_info, esp_now_send_status_t status) {
  if (status == ESP_NOW_SEND_SUCCESS) {
    Serial.println("Send Success");
  } else {
    Serial.println("Send Fail");
  Serial.begin(115200);
  myData.b = 0;
  WiFi.mode(WIFI_STA);
  if (esp_now_init() != ESP_OK) {
    Serial.println("Error initializing ESP-NOW");
    return;
  esp_now_register_send_cb(OnDataSent);
  memcpy(peerInfo.peer_addr, broadcastAddress, 6);
  peerInfo.channel = 0;
  peerInfo.encrypt = false;
  if (esp_now_add_peer(&peerInfo) != ESP_OK) {
    Serial.println("Failed to add peer");
    return;
  pinMode(Rgt, OUTPUT);
  pinMode(Lft, OUTPUT);
  while (!(asr.begin())) {
    Serial.println("Communication with device failed, please check connection");
    delay(3000);
  Serial.println("Begin ok!");
  asr.setVolume(7);
  asr.setMuteMode(0);
  asr.setWakeTime(255);
  uint8_t wakeTime = 0;
  wakeTime = asr.getWakeTime();
  Serial.print("wakeTime 4= ");
  Serial.println(wakeTime);
  // asr.playByCMDID(1);   // Wake-up command
     @brief Play the corresponding reply audio according to the ID
     @param CMDID - command word ID
  pinMode(RbuttonPin, INPUT);
  pinMode(LbuttonPin, INPUT);
  RbuttonPin = HIGH;
  LbuttonPin = HIGH;
  LbuttonState = digitalRead(LbuttonPin);
  if (LbuttonState != LlastButtonState) {
    LbuttonPushCounter++;
  if (LbuttonPushCounter >= 2) {
  uint8_t CMDID = 0;
  CMDID = DF2301Q.getCMDID();
  Serial.print("CMDID = ");
  Serial.println(CMDID);
  if (CMDID == 5) {
    digitalWrite(Lft, LOW);
    while ((RbuttonPushCounter < 2)) {
      digitalWrite(Rgt, HIGH);
      delay(1000);
      digitalWrite(Rgt, LOW);
      delay(1000);
      RbuttonState = digitalRead(RbuttonPin);
      Serial.print("now ");
      Serial.println(RbuttonState);
      Serial.print("last ");
      Serial.println(RlastButtonState);
      if (RbuttonState != RlastButtonState) {
        RbuttonPushCounter++;
        (RlastButtonState = RbuttonState);
        Serial.print("CNT = ");
        Serial.println(RbuttonPushCounter);
     if ((RbuttonPushCounter >= 2)) {
        break;
  if (CMDID == 7) {
    digitalWrite(Rgt, LOW);  // Turn Relay OFF
    Serial.println("Relay Deactivated");
  delay(500);
  //GREEN = 8, WHITE = 9, RED = 10, CRUISE ON = 11, CRUISE SET = 12, ADAPT ON = 13, NEAR = 14, FAR = 15
  if (CMDID == 0 || CMDID == 8 || CMDID == 9 || CMDID == 10 || CMDID == 11 || CMDID == 12 || CMDID == 13 || CMDID == 14 || CMDID == 15 || CMDID == 16) {
    (myData.b = CMDID);
    (CMDID == 0);
    Serial.println(myData.b);
    uint8_t data[sizeof(myData)];
    memcpy(data, &myData, sizeof(myData));
    esp_err_t result = esp_now_send(broadcastAddress, (uint8_t *)&myData, sizeof(myData));
    //       esp_now_send(peerAddress, data, sizeof(data));
    if (result == ESP_OK) {
      Serial.println("Sent with success");
    } else {
      Serial.println("Error sending the data");
  delay(1000);
2026-08-03 10:00:27
The code declares a UART object DF2301Q but never uses it — instead it calls asr.begin() on an I2C object asr, which will never succeed since your wiring is UART on D6/D7. That's why it hangs on initialization.
Stick to one object. Since you're wired for UART, drop the I2C asr entirely and use DF2301Q.begin() instead. The UART constructor for ESP32 takes &Serial1, rx, tx — your D6/D7 mapping looks right for XIAO C3.
For power-on wake, uncomment playByCMDID(1) after begin() — that forces the module into wake state. setWakeTime(255) keeps it there for about 4 minutes. If you need it awake indefinitely, poll getCMDID() in your loop and re-send playByCMDID(1) when it drops back to standby.
Also RbuttonPin = HIGH overwrites your pin number with 1 — you'll want digitalWrite(RbuttonPin, HIGH) or just remove those two lines.
userHeadPic Jason.Miao
