SEN0604 EC Value Is Always 0
Mitsu.Yama 2026-08-03 14:50:39 438 Views3 Replies I have a question.
I purchased the sensor introduced at:
https://wiki.dfrobot.com/sen0604/
and connected it to an Arduino UNO R3 via the RS485 Shield introduced at:
https://www.dfrobot.com/product-1024.html
I then ran the following sketch, which is provided here:
https://wiki.dfrobot.com/sen0604/docs/20298
uint8_t Com[8] = { 0x01, 0x03, 0x00, 0x00, 0x00, 0x04, 0x44, 0x09 };
float tem, hum, ph;
int ec;
Serial.begin(9600);
readHumitureECPH();
Serial.print("TEM = ");
Serial.print(tem, 1);
Serial.print(" °C ");
Serial.print("HUM = ");
Serial.print(hum, 1);
Serial.print(" %RH ");
Serial.print("EC = ");
Serial.print(ec, 1);
Serial.print(" us/cm ");
Serial.print("PH = ");
Serial.println(ph, 1);
delay(1000);
void readHumitureECPH(void) {
uint8_t Data[13] = { 0 };
uint8_t ch = 0;
bool flag = 1;
while (flag) {
delay(100);
Serial.write(Com, 8);
delay(10);
if (readN(&ch, 1) == 1) {
if (ch == 0x01) {
Data[0] = ch;
if (ch == 0x03) {
Data[1] = ch;
if (ch == 0x08) {
Data[2] = ch;
if (readN(&Data[3], 10) == 10) {
if (CRC16_2(Data, 11) == (Data[11] * 256 + Data[12])) {
hum = (Data[3] * 256 + Data[4]) / 10.00;
tem = (Data[5] * 256 + Data[6]) / 10.00;
ec = Data[7] * 256 + Data[8];
ph = (Data[9] * 256 + Data[10]) /10.00;
flag = 0;
Serial.flush();
uint8_t readN(uint8_t *buf, size_t len) {
size_t offset = 0, left = len;
int16_t Tineout = 500;
uint8_t *buffer = buf;
long curr = millis();
while (left) {
if (Serial.available()) {
buffer[offset] = Serial.read();
offset++;
left--;
if (millis() - curr > Tineout) {
break;
return offset;
unsigned int CRC16_2(unsigned char *buf, int len) {
unsigned int crc = 0xFFFF;
for (int pos = 0; pos < len; pos++) {
crc ^= (unsigned int)buf[pos];
for (int i = 8; i != 0; i--) {
if ((crc & 0x0001) != 0) {
crc >>= 1;
crc ^= 0xA001;
} else {
crc >>= 1;
crc = ((crc & 0x00ff) << 8) | ((crc & 0xff00) >> 8);
return crc;
When I inserted the sensor into the soil and ran this sketch, the values for TEM, HUM, and PH were displayed correctly, but the EC value was always 0.
I tested two different sensors, but the EC value was still always 0 with both of them.
Could you please let me know what might be causing this issue and how I can get the sensor to output the correct EC value?
The first two SEN0604 sensors I purchased continued to show EC = 0, even when they were completely submerged in water.
However, the two SEN0604 sensors I purchased a little later worked normally and output EC values without any problems.
It seems that, purely by coincidence, the first two SEN0604 sensors happened to fail at the same time.
In a way, the problem is now solved. Sorry for the trouble, and thank you for your help.
Mitsu.Yama Once the problem is solved, feel free to share any remaining issues.
EC reads zero when the probe isn't fully buried or the soil is too dry — the steel needles need to be completely surrounded by moist soil for the conductivity circuit to close. Temperature and humidity will show numbers with partial contact, but EC won't. The Wiki notes that the probe must be fully inserted and the soil water content should be above roughly 20 % for soluble ions to register. If your soil is sandy or bone-dry, the actual conductivity can be near zero. Since both sensors behave the same, the hardware and code are fine. Try pushing the probe all the way in vertically without wiggling it, or drop it into a glass of tap water as a quick sanity check — the sensor is IP68, so water won't hurt it.
Jason.Miao
