DF2301Q different response to playByCMDID(1) vs. playByCMDID(2)
Steve.Parus 2026-08-04 10:52:39 315 Views1 Replies DF2301Q voice recognition module:
playByCMDID(1); = Learned wake-up command :
response is 'Yes, I'm here',
blue LED turns On
module does respond to commands
then module times out and says 'I'm Off now'
playByCMDID(2); = Default wake-up command :
blue LED does Not turn On
and does not respond to spoken commands
and module does not say 'I'm Off now'
Why does its commanded wake-up behavior differ between its learned and default words ?
CMDID 1 is hard-coded in the firmware as the "enter wake-up state" command, not just an audio clip. When you call playByCMDID(1), the module switches to active listening mode — blue LED on, command recognition enabled, wake timer started — and the "Yes, I'm here" reply is just the audio side effect.
CMDID 2 is only the default wake-word audio reply. It plays the sound but doesn't flip the state machine, so if the module was sleeping it stays sleeping — no LED, no command listening, no timeout announcement.
If you want the default wake word to behave the same way, use settingCMD(DF2301Q_UART_MSG_CMD_SET_ENTERWAKEUP, 0) to force wake state, or stick with playByCMDID(1) since both wake words share the same active mode once the module is awake.
Jason.Miao
