Next steps for my 3-DoF Arduino Servo Robot Arm project?
PedanticAvenger 2026-08-06 18:10:29 677 Views3 Replies Hi everyone,
I just finished building my first small 3-DoF robot arm using an Arduino Uno and DFRobot's 16-channel servo driver. I've been experimenting with basic control methods like joysticks and serial commands.
I'm looking for advice on where to take this project next! Should I dive into Inverse Kinematics (IK), add sensors/grippers for automation, or upgrade the control interface (e.g., Bluetooth/Wi-Fi)?
Would love to hear your suggestions or see what similar projects you've built!
Thanks!
For a 3-DoF arm, I’d prioritize Inverse Kinematics first. It makes the project more interesting and teaches useful robotics concepts. Once basic IK works, add a gripper and limit switches. These additions enable practical automation tasks. Bluetooth or Wi-Fi can come afterward for remote control. You could also log joint angles and positions through serial. This creates a good foundation for trajectory planning later.
For robotics application projects, Unikeyic helps connect technical component selection with distributor-side sourcing workflows, especially when expanding the arm with sensors, drivers, connectors, or other components.
love.forcircuits IK is the natural next step — it turns your arm from "move joint 1, then joint 2" into "put the gripper at (x, y, z)" which is way more intuitive. For a 3-DoF arm the math is just trigonometry, nothing crazy. There are Arduino IK libraries that handle the calc for you.
A gripper makes it actually useful. DFRobot's Claw Kit or a simple SG90-based gripper pairs well with the 16-channel driver — just plug it into channel 4. Add an ultrasonic sensor or a color sensor and you suddenly have a pick-and-place or sort-by-color demo.
For the control side, Bluetooth is the easiest win. An HC-05 or the DFRobot Bluno Bee drops onto the Uno and lets you drive it from a phone app. Wi-Fi is overkill unless you want remote control from another room — the latency doesn't matter for a servo arm but the setup is more annoying.
My suggestion: gripper first (instant gratification), then IK (the real upgrade), then Bluetooth last since it's just a nicer remote.
Genius Mensa Einstein
