DFRobot and loop execution
DENNIS.BRANDT 2026-08-13 01:41:13 372 Views1 Replies I have been working on this sketch for several days and tried various alternatives. When I make a sketch of the code between the //***************'s it works fine. When I add it to the overall sketch it won't cycle or turn on the relay.
Any Suggestions
#include "DFRobot_DF2301Q.h"
#include <esp_now.h>
#include <WiFi.h>
uint8_t broadcastAddress[] = { 0x14, 0x08, 0x08, 0xa5, 0xd7, 0x68 };
DFRobot_DF2301Q_UART DF2301Q(/*hardSerial =*/&Serial1, /*rx =*/D7, /*tx =*/D6);
const byte BUTTON_PIN = D2;
const byte RELAY_PIN = D0;
volatile byte buttonPressCount = 0;
volatile unsigned long lastDebounceTime = 0;
const unsigned long DEBOUNCE_DELAY = 1000;
bool isCycling = true;
typedef struct struct_message {
int b;
} struct_message;
struct_message myData;
esp_now_peer_info_t peerInfo;
DFRobot_DF2301Q_I2C asr;
void OnDataSent(const esp_now_send_info_t *tx_info, esp_now_send_status_t status) {
if (status == ESP_NOW_SEND_SUCCESS) {
Serial.println("Send Success");
} else {
Serial.println("Send Fail");
Serial.begin(115200);
myData.b = 0;
WiFi.mode(WIFI_STA);
if (esp_now_init() != ESP_OK) {
Serial.println("Error initializing ESP-NOW");
return;
esp_now_register_send_cb(OnDataSent);
memcpy(peerInfo.peer_addr, broadcastAddress, 6);
peerInfo.channel = 0;
peerInfo.encrypt = false;
if (esp_now_add_peer(&peerInfo) != ESP_OK) {
Serial.println("Failed to add peer");
return;
while (!(asr.begin())) {
Serial.println("Communication with device failed, please check connection");
delay(3000);
Serial.println("Begin ok!");
asr.setVolume(7);
asr.setMuteMode(0);
asr.setWakeTime(255);
uint8_t wakeTime = 0;
wakeTime = asr.getWakeTime();
Serial.print("wakeTime 4= ");
Serial.println(wakeTime);
// asr.playByCMDID(1); // Wake-up command
@brief Play the corresponding reply audio according to the ID
@param CMDID - command word ID
pinMode(RELAY_PIN, OUTPUT);
pinMode(BUTTON_PIN, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(BUTTON_PIN), handleButtonPress, FALLING);
digitalWrite(RELAY_PIN, LOW);
uint8_t CMDID = 0;
CMDID = DF2301Q.getCMDID();
Serial.print("CMDID = ");
Serial.println(CMDID);
if (CMDID == 5) {
if (buttonPressCount >= 5) {
isCycling = false;
if (isCycling) {
digitalWrite(RELAY_PIN, HIGH);
delay(1000);
delay(1000);
} else {
void handleButtonPress() {
unsigned long currentTime = millis();
if ((currentTime - lastDebounceTime) > DEBOUNCE_DELAY) {
buttonPressCount++;
lastDebounceTime = currentTime;
Your code declares a UART object DF2301Q but initializes an I2C object asr in setup, then reads from the UART object in loop. The UART path was never opened — DF2301Q.begin() is missing — so getCMDID() returns 0 every time and CMDID == 5 never fires.
Pick one interface. If your wiring is UART on D6/D7, drop the I2C asr entirely and call DF2301Q.begin() in setup. If you're wired for I2C, use asr.getCMDID() in loop instead.
The relay not cycling is just a symptom — the voice command never registers because the wrong object is being polled.
Jason.Miao
