General Robotics
Missing Encoder Output Type & Encoder Output Ranges In Datasheet, SKU: FIT0186
userHead duytruongcute 2026-08-23 23:34:28 324 Views2 Replies
Hi, I’m using this motor’s quadrature encoder with an ESP32. Are the outputs of this motor push-pull, open-collector, or open-drain? Also, is the maximum output 5V or 3.3V? I'm trying to connect it to ESP32 but its GPIO only accepts 3.3V. Do I have to level shift the outputs when connecting? Thanks.
2026-08-24 08:58:41
The encoder is said to be 5V. You'd better not try using your 3.3V GPIO port.
userHeadPic Jason.Miao
2026-08-24 08:55:10
The wiki lists encoder operating voltage as 5V but doesn't say if the outputs are push-pull or open-collector.
Quick way to check: power the encoder and measure the A/B pins with a multimeter while the motor is still. If you see ~5V sitting there it's push-pull. If they're floating near 0V it's likely open-collector.You can give it a try and share your results. Then we can see what the actual situation is like.
