What Should You Consider When Choosing an LCD for Measurement Equipment?
Todorov.Alexandar 2026-08-26 16:37:21 10 Views0 Replies When building an industrial measurement device, the LCD display is more than a component for showing numbers. It becomes part of the operator interface and needs to work reliably with the measurement system, processor, enclosure, and operating environment. Choosing a suitable display therefore requires looking beyond screen size and resolution.
For example, a compact measuring instrument may only need to show a few numerical values, while a larger test system may need to display charts, multiple channels, warning messages, configuration menus, and real-time measurement data.
Here are several practical factors engineers should consider when selecting an LCD for this type of equipment.
Start With the Information You Need to Display
The user interface should be considered before choosing the LCD.
If the device only displays numerical readings, a smaller TFT display with a moderate resolution may be enough. However, if the interface needs to show waveforms, graphs, multiple measurement channels, trend information, or detailed menus, a larger resolution and active area may provide a better experience.
It is useful to consider:
How many values need to be displayed at the same time
Whether graphs or waveforms are required
The smallest text that operators need to read
The typical viewing distance
Whether the display will be installed vertically or horizontally
How complicated the graphical interface will be
A display that is technically compatible with the controller may still be unsuitable if the interface becomes crowded or difficult to read.
Screen Size Should Match the Equipment
There is no universal screen size for measurement equipment.
Portable instruments normally have strict space limitations, making compact LCD modules more practical. Larger test stations or monitoring systems have more room and may benefit from a larger active area.
The enclosure should be evaluated together with the LCD module. Important dimensions include the overall module size, active area, thickness, mounting holes, connector position, and cable routing.
Choosing a very large display simply because it provides more viewing area can create unnecessary mechanical and cost challenges.
Resolution Affects Measurement Readability
Measurement interfaces often contain small numbers, decimal values, units, tolerances, graphs, and status information.
A suitable resolution helps separate these elements and makes the interface easier to understand. Higher resolution can be particularly useful when the system displays detailed charts or several measurement parameters simultaneously.
However, higher resolution is not automatically better.
The display resolution should be balanced against the processor, display controller, software interface, power requirements, and overall system cost. For a simple measurement interface, an excessively high-resolution panel may provide little practical benefit.
Brightness Depends on the Installation Environment
Brightness should be selected according to the actual lighting conditions.
A device operating inside a laboratory or enclosed factory environment may not require the same brightness as equipment installed close to windows, factory entrances, or semi-outdoor areas.
If strong ambient light is expected, engineers should also consider contrast, surface treatment, and optical performance rather than looking at brightness alone.
For applications exposed to strong ambient light, features such as:
High-brightness backlight
Improved contrast
Anti-glare treatment
Optical bonding
Sunlight-readable design
may help improve visibility.
The goal is not simply to select the brightest possible display. The goal is to make measurement information consistently readable in the actual operating environment.
Check the LCD Operating Temperature
Temperature is another important consideration for industrial equipment.
Measurement systems may operate in factories, warehouses, equipment cabinets, production areas, or environments with significant seasonal temperature changes. A standard display designed for controlled indoor conditions may not always be appropriate.
Temperature can influence LCD characteristics such as response time, contrast, backlight behavior, and long-term stability.
Before selecting a panel, engineers should compare the LCD's specified operating temperature range with the expected conditions of the complete system.
For equipment exposed to unusually high or low temperatures, a wide-temperature LCD module may be worth considering.
Make Sure the Interface Matches the Mainboard
The LCD interface should be selected together with the processor and system architecture.
Common interfaces used with TFT LCD modules include RGB, LVDS, MIPI, and eDP. The correct option depends on the processor, controller, resolution, cable requirements, transmission distance, and overall hardware design.
For example, an interface that works well with one embedded platform may require additional hardware or a different configuration on another platform.
Before ordering samples, engineers should verify:
Processor or display controller compatibility
Interface type
Pin configuration
Resolution support
Signal requirements
Connector type
Cable length
EMI considerations
Matching the LCD interface to the existing hardware early in the design process can reduce integration work later.
Viewing Angle Can Matter More Than Expected
Measurement equipment is not always operated directly in front of the display.
A production-line tester, laboratory instrument, or shared monitoring terminal may be viewed from different positions. In these situations, a wide viewing angle can make measurement information easier to read.
IPS-based TFT LCD technology is often considered when consistent image quality from different viewing directions is important.
The appropriate display technology should depend on the actual viewing requirements rather than simply selecting a panel based on resolution.
Decide Whether a Touch Panel Is Necessary
Some measurement devices continue to use physical buttons, while others use a touch panel for configuration and navigation.
A touch interface can be useful when operators need to change parameters, switch measurement modes, browse historical data, or interact with graphical menus.
The choice of touch technology should also reflect the working environment.
For example, capacitive touch panels can provide a responsive interface for modern graphical controls, while resistive touch technology can be considered for applications involving gloves or specific operating conditions.
Other factors include surface durability, contamination, sensitivity, enclosure integration, and the expected method of operation.
It is generally better to consider the LCD and touch panel as one integrated HMI solution rather than selecting each component independently.
Mechanical Integration Should Be Checked Early
A display can have suitable electrical specifications and still fail to fit the equipment mechanically.
Before finalizing a panel, check the complete mechanical drawing and verify:
Overall dimensions
Active area
Module thickness
Mounting locations
Bezel requirements
Connector location
Cable direction
Enclosure clearance
Connector placement is particularly important in compact instruments because there may be very limited space behind the display.
Early mechanical verification can prevent a situation where the selected LCD works electrically but requires a redesign of the enclosure.
Long-Term Availability Matters for Industrial Equipment
Industrial measurement products often remain in production for considerably longer than typical consumer devices.
For this reason, engineers should think about more than the initial sample.
Display availability, supply continuity, quality consistency, and long-term technical support can all influence the total development risk.
Replacing an LCD after the equipment has entered production may involve changes to:
Mechanical parts
Display cables
Driver boards
Software configuration
Touch integration
Testing and certification
A display that is well matched to the application from the beginning can therefore reduce the risk of future redesign.
Consider Customization When Standard Modules Are Not Enough
Some measurement equipment has requirements that cannot be met easily with an off-the-shelf LCD module.
Depending on the project, customization may involve display brightness, touch panel integration, cable configuration, interface selection, mechanical dimensions, or optical requirements.
For engineers working on a new measurement platform, discussing these requirements with an LCD supplier at an early stage can help identify potential integration problems before the design is finalized.
For a more detailed technical overview of the selection process, this guide on LCD display for industrial measurement equipment covers factors such as resolution, brightness, operating temperature, interfaces, touch integration, viewing angle, and mechanical compatibility:
How to Choose an LCD Display for Industrial Measurement Equipment
Final Thoughts
Selecting an LCD for industrial measurement equipment is ultimately a system-level decision.
Screen size and resolution are important, but they are only part of the selection process. Engineers should also evaluate brightness, temperature range, viewing angle, interface compatibility, touch requirements, mechanical dimensions, and long-term availability.
The best LCD is not necessarily the largest or highest-resolution panel. It is the display that fits the equipment's user interface, hardware architecture, operating environment, and product lifecycle requirements.
