Using DFPlayer Pro Without Arduino Code
MIchaelAnderson 2026-09-20 02:01:29 362 Views1 Replies I am building a simple Halloween project using the Arduino Uno R3 controller and I want to play a sound effect from a DFPlayer Pro sound module without any coding. My reading so far suggests that this is possible, but I don't know how to do it.
There will be one sound file on the sound module. I think I should be able to use one of the Arduino output pins to trigger the sound effect to play one time. My thinking right now is that I should be able to trigger the sound card (at its Key input) with a (HIGH) command from one of the Uno output pins. I would turn off the trigger pin (LOW) after the sound effect has played.
I would like to avoid any coding and wiring of the RX/TX connections, as mentioned before. Both the Arduino Uno R3 and DF Player Pro module are original name brand items, no knock-offs.
There's no trigger pin on the DFPlayer Pro — PLAY/KEY are just the onboard buttons, so you can't drive them from an Uno pin. Because it's a decoder board, not a simple button-trigger module.
To play an exact file you have to go through UART:
TX→RX, TX→RX but put a 1kΩ resistor on the RX line (Uno is 5V, module RX is 3.3V)
then myDFPlayer.playFileNum(1)
That's the way to auto-play one track. The ADKEY pins are just manual buttons (next/prev/volume), not a clean trigger either.
Jason.Miao
