A01NYUB Ultrasonic Distance Sensor on pi 5 without Expansion Board?
Jose.Sampson 2026-09-28 14:50:54 254 Views4 Replies Hello,
I am trying to run the A01NYUB Ultrasonic Distance Sensor with my pi 5 directly (no Expansion Board).
I use the https://github.com/DFRobot/DFRobot_RaspberryPi_A02YYUW_driving directions library.
Unfortunately, I only get “No data!”.
Any suggestions?
I use the https://github.com/DFRobot/DFRobot_RaspberryPi_A02YYUW_ library.
Any suggestions?
driving directions
Jose.Sampson hi,
First, raw-read the port directly. Open the serial port with raspi-config (Interface Options → Serial Port: disable the login shell on it, enable the serial hardware), then just read the raw stream at 9600 baud. Wave a hand in front of the sensor while you read.
Second, confirm which sensor you're actually holding. The repo you linked is for the A02YYUW - a different model from the one in your title. The A01NYUB actively reports its distance on its own, once every few hundred milliseconds, on a 9600 baud stream, with a different frame layout than the A02YYUW. If your part is the A01NYUB, you should use its own example and baud rate - wiring it up through the A02YYUW driver will throw the frames away, because it's expecting a different packet shape and won't recognize yours. That mismatch alone produces "No data!" even when everything is wired correctly.
