Unable to communicate with GNSS RTK Mobile KIT0198 EU using NVIDIA Jetson Nano via I2C or UART
Enoch.Asante 2026-09-28 17:29:10 333 Views6 Replies Hello,
I am trying to connect the DFRobot GNSS RTK High Precision Positioning Kit mobile station, KIT0198 EU, to an NVIDIA Jetson Nano, but so far I have not been able to establish communication using either I2C or UART.
I2C test
I connected the mobile station to the Jetson Nano I2C interface and set the selector switch on the RTK Mobile to I2C.
On the Jetson I ran:
sudo i2cdetect -y -r 1
The Jetson sees devices at 0x24 and 0x40, but there is no response at 0x20.
According to the DFRobot library and documentation, I understand that the RTK Mobile should normally use I2C address 0x20.
I have also tried scanning without the -r option.
UART test
I then changed the selector switch to UART, power cycled the RTK Mobile, and connected:
RTK TX to Jetson RX
RTK RX to Jetson TX
RTK GND to Jetson GND
I tested 115200 baud as well as other common UART baud rates, but I could not receive any NMEA output.
I expected to see messages such as:
$GNGGA,... $GNRMC,...
but no serial data was received.
Oscilloscope test
We also checked the communication lines using an oscilloscope.
We were unable to observe useful communication data from the module on the interface lines.
The RTK Mobile powers on, but communication with the Jetson Nano is currently not working.
Could someone from DFRobot please help confirm the following?
Is 0x20 definitely the correct I2C address for the KIT0198 EU mobile station?
Should the mobile station appear directly in i2cdetect when the selector is in I2C mode?
Is any initialization required before the device responds on I2C?
What I2C clock frequency should be used?
What is the factory UART baud rate?
When switched to UART mode, should the mobile station continuously output NMEA data immediately after power up?
Is any configuration required before changing from I2C to UART?
Is there a recommended Linux or NVIDIA Jetson example for communicating with this module?
Are there any additional diagnostic points or LEDs we can check to confirm that the internal GNSS module and interface controller are operating correctly?
If necessary, I can also provide photos of the wiring, oscilloscope measurements, Jetson pin connections, and additional terminal output.
Thank you for your help.
Enock
I did not use any control boards, just hooking the scope's probe on UART Tx line to check the activity. I'm going to use a laptop to obtain GPS fixes generated by the KIT0198. The Laptop's native RS232 port will be connected to the KIT0198 via UART/TTL ←→ RS232 converter.
yakov Have you tried the several suggestions I proposed?Then could you check if it's a positioning issue? Try to see if there is any serial port output after the positioning is successful.
I'd isolate this on a known-good host (Arduino MEGA/ESP32 with the RTK example) before blaming the Jetson front-end. If it works there, it's the Jetson serial setup; if it doesn't, it's the module/wiring.
Good that you power-cycled after switching modes - that's required. A few things to zero in on:
Jason.Miao Hi, I have similar problem - the mobile unit does not talk to UART. I've expected the mobile device will output GPS-fixes without any initial programming/configuration - right?
Checking the Tx line with scope confirms no UART activity at the output. Both base and mobile are placed outside the room to get clear GPS receiption, blue LED flashes.
Any suggestions?
To yakov: your expectation is actually correct — the KIT0198-EU rover is pre-configured out of the box (NMEA 0183, raw update 1Hz), so it should output NMEA on UART without any programming. If the scope shows zero activity on TX, check these in order:
1) the UART/I2C toggle switch must be in the UART position — in I2C mode the UART lines are silent;
2) the baud rate — Please set the baud rate according to the information on the wiki. It is best to follow the official example tutorials. This will best determine whether the hardware itself is damaged. https://wiki.dfrobot.com/kit0198-eu/docs/21395
In addition, I would like to ask what type of main control board you are using. Could you please send me the wiring diagram so I can have a look?
The flashing of the LED blue light indicates that the positioning is in progress. It is also possible that no output is generated during the positioning process.
