Looking for CAD Files or Technical Drawings for the Baron-4WD Robot Platform
userHead Len.40 2026-10-19 19:56:23 194 Views1 Replies
Hi everyone,
I’m currently working on a robotics project and plan to use the Baron-4WD Mobile Robot Platform for Arduino with Encoder as the chassis for a combat robot I’m building.
I was wondering if anyone has access to a CAD model of this platform, preferably in STEP (.step/.stp) format. If a CAD file isn’t available, any technical drawings, dimensions, or mechanical specifications would be greatly appreciated.
I’m looking to design custom armour and a weapon system around the chassis, so having accurate measurements would be a big help. In particular, I’m interested in:
Mounting-hole positions and spacing
Mounting points and hole sizesChassis layout and mechanical detailsAny existing CAD models or technical drawings
If anyone has worked with this platform before or knows where I might be able to find these files, I’d really appreciate any help or advice.
Thanks in advance!
2026-10-21 14:25:43
This does not have a step model, but the product page and the wiki have specific parameters. You can take a look at them first. If that doesn't work, you can purchase one and test it yourself.
userHeadPic Jason.Miao
