A02YYUW Ultrasonic Sensor – Transducer Face Material and Additional Protective Membrane
Aya.Abdelwahab 2026-10-26 21:56:35 801 Views3 Replies I am using the A02YYUW waterproof ultrasonic distance sensor (SEN0311) in a Smart Zamzam Tank monitoring project. The sensor will be installed in the tank lid to measure the water level without directly contacting the water.
I would appreciate your help with the following questions:
1-What material is used to cover the two ultrasonic transducer faces on the A02YYUW sensor?
2-If I need to add an additional protective layer between the sensor and the tank's internal air space to provide an extra barrier against moisture and contamination, what material would you recommend?
3-Can the sensor operate reliably through a thin plastic membrane, such as polypropylene (PP) or polyethylene (PE), without significantly affecting its measurement accuracy or echo detection?
4-If an additional membrane is possible, what material and thickness would you recommend for operation at approximately 40 kHz?
5-Does adding such a membrane affect the sensor's measurement range, accuracy, or waterproof rating?
The purpose of this design is to keep the sensor electronics protected while measuring the water level without introducing any components into the water. Hygiene is particularly important for this application.
Thank you for your time and technical support. I look forward to your recommendations.
Hi Aya, I’d confirm the transducer-face material with DFRobot before choosing an additional barrier. The SEN0311 documentation specifies 40 kHz ±1 kHz and IP67, but I couldn’t find a material specification for the faces or an approved protective membrane.
I wouldn’t assume that a thin PP or PE film will be acoustically transparent. The transmitted pulse and returning echo both have to cross it, and the film can introduce reflections or reduce the received signal. Thickness alone is insufficient to predict performance; the mounting, air gap and condensation also matter. MaxBotix’s guidance on covering ultrasonic sensors(https://maxbotix.com/pages/methods-to-conceal-an-ultrasonic-sensor) explains these problems for its 42 kHz sensors, including materials that work dry but stop working when wet. That is useful background, rather than validation for the A02YYUW.
If a complete barrier is essential, I’d ask DFRobot and an acoustic-membrane supplier for a specific material and mounting arrangement characterised around 40 kHz. I wouldn’t recommend a particular thickness without those data. Any candidate should be compared against the uncovered sensor across your full tank-level range, including condensation conditions, checking missed readings and false close-range echoes as well as distance error.
Adding a cover does not automatically improve the finished assembly’s waterproof rating, and the original sensor’s IP67 rating does not establish suitability for drinking-water service. Since condensate could drip back into the tank, the exposed membrane, adhesive and seals also need suitable material documentation and compatibility with your cleaning method.
For the electronics and enclosure side, the Twin Node water-level monitoring project on PCBWay(https://www.pcbway.com/project/shareproject/Twin_Node_V2_0_WaterLevelMonitor_e9a6baad.html) provides a waterproof-ultrasonic monitoring example with schematics and enclosure-model links. It can help with packaging ideas, but it doesn’t establish membrane compatibility or hygienic suitability for this application.
ahsrab.rifat I’d recommend checking with DFRobot about the transducer face material before adding any protective layer. At around 40 kHz, even a thin plastic membrane can affect sound transmission and echo detection, depending on its material, thickness, and tension. PP or PE may work, but I’d test the sensor’s accuracy before using it in the tank. For hygiene, keeping the sensor outside the water and using a properly tested moisture barrier seems like the safest approach.
[url=https://crossy-road.io][color=#FFFFFF]Crossy Road[/color][/url]
wsgdfg If a membrane is added, the membrane itself will generate echoes, which may affect the accuracy. First, conduct a bare measurement on the lid of the container. If condensation/pollution is indeed observed during the measurement, then add the membrane. If you decide to add it, use 50µm and 100µm PP and measure one round at the actual depth of the container, comparing it with the baseline of the bare sensor. If the measured results are acceptable to you, then your problem can be directly solved.
Jason.Miao
