Troubleshooting
UPS Board max voltage?
userHead Brent Simpson 2026-11-14 08:22:54 28 Views0 Replies
I'm using a LattePanda 3 Delta, (fitted with the UPS hat) for a Weighing and Load Management System on my Volvo Excavator, which has a regulated 24V DC supply available, and the UPS works just fine.  Recently, I been operating a Big Kobelco SR350LC excavator but the DC output is not regulated and the voltage follows whatever the alternator is providing.  When measured with a Fluke multimeter I measured 27.4V DC just after start up, so once the batteries are topped up it'll probably sit around 28V.  The LattePanda 3 Delta UPS shuts off, probably because of overvoltage.
Two questions,
- Is there any way of increasing the input voltage range?
I'm considering the use of the IOTA board (if they ever become available).
- The IOTA UPS spec input voltage only mentions 12-24V.  Does anybody know what the 24V upper limit is?
If your interested in the project, have a look at https://brandysystems.com/excavator-load-management-system/.  It uses a trained .onnx model which identifies 24 classes of bucket types and Bucket Phases, Video processing on GPU (24 FPS), Flask to serve almost real time web pages to the operators phone, and PostgreSQL for the data base.
