path remembering car
Account cancelled 2012-11-01 10:07:06 5012 Views0 Replies I am trying to build a robot that remembers the path that it just passed, to do that I am using two wheel encoders. I bought the wheel encoders form DFrobots and used the sample code they have to test the encoders here is the code:
But the sensors are giving me wrong readings, even when I disconnect the pins it still give me weird readings. Does that mean that is something is wrong with the code or are the encoders bad?
(this is just a test it is not the code for the entire project.)#include <AFMotor.h>
AF_DCMotor motor1(1, MOTOR12_64KHZ);
AF_DCMotor motor2(2, MOTOR12_64KHZ);
AF_DCMotor motor3(3, MOTOR12_1KHZ);
AF_DCMotor motor4(4, MOTOR12_1KHZ);
const int pingPin = 19;
#define LEFT 0
#define RIGHT 1
long coder[2] = {
0,0};
int lastSpeed[2] = {
0,0};
Serial.begin(9600); // set up Serial library at 9600 bps
motor1.setSpeed(200); // Set the speed for the motors (255 is the maximum)
motor2.setSpeed(200);
motor3.setSpeed(200);
motor4.setSpeed(200);
attachInterrupt(LEFT, LwheelSpeed, CHANGE); //init the interrupt mode for the digital pin 2
attachInterrupt(RIGHT, RwheelSpeed, CHANGE); //init the interrupt mode for the digital pin 3
void forward(){ // This function moves the wheels forward
motor1.run(FORWARD);
motor2.run(FORWARD);
motor3.run(FORWARD);
motor4.run(FORWARD);
void backward() { // This function moves the wheels backward
motor1.run(BACKWARD);
motor2.run(BACKWARD);
motor3.run(BACKWARD);
motor4.run(BACKWARD);
void haltMotors() // This function stops each motor (It is better to stop the motors before changing direction.)
motor1.run(RELEASE);
motor2.run(RELEASE);
motor3.run(RELEASE);
motor4.run(RELEASE);
void turnRight(){ // This function turns the robot right.
void turnLeft(){
forward();
delay(500);
haltMotors();
delay (1000);
static unsigned long timer = 0; //print manager timer
if(millis() - timer > 100){
Serial.print("Coder value: ");
Serial.print(coder[LEFT]);
Serial.print("[Left Wheel] ");
Serial.print(coder[RIGHT]);
Serial.println("[Right Wheel]");
lastSpeed[LEFT] = coder[LEFT]; //record the latest speed value
lastSpeed[RIGHT] = coder[RIGHT];
coder[LEFT] = 0; //clear the data buffer
coder[RIGHT] = 0;
timer = millis();
void LwheelSpeed()
coder[LEFT] ++; //count the left wheel encoder interrupts
void RwheelSpeed()
coder[RIGHT] ++; //count the right wheel encoder interrupts
