Bluetooth bee and phone not connecting
The Crusher 2012-10-12 12:52:31 6374 Views19 Replies Hi,
When I try to connect my phone to my bluetooth bee I just get an error message that I can not connect to it. What can I do to get it to work? The phone is an Samsung Galaxy xcover.
2012-10-22 18:54:31 Hi,
I'm glad both are working. Some bluetooth modules do have compatibility issues.
I'll take a look at those AT commands to add them to our wiki.
Thanks.
Hector
Thanks.
Hector 2012-10-22 18:54:31 Hi,
Thanks.
Hector
Thanks.
Hector 2012-10-20 13:34:04 I fixed it. Just did some more commands. Did the same to my bluetooth mate gold, so both works with phone. But thei do not work together...
The Crusher
The Crusher 2012-10-20 13:34:04 I fixed it. Just did some more commands. Did the same to my bluetooth mate gold, so both works with phone. But thei do not work together...
The Crusher
The Crusher 2012-10-20 08:32:40 I did a factory reset trough AT commands, and now I can connect to it, and send commands. but, I do not recieve the same char that i send. I send W, S, A, D, Q, E, F and V different times, to controll my rc car, but all i recieve is this:
þþþþþÿþþþþþÿþþÿÿþþþþÿþÿþþÿþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþþ
+ a bunch more.....
What to do about that?
The Crusher
+ a bunch more.....
+ a bunch more.....
The Crusher
+ a bunch more.....
The Crusher 2012-10-20 03:02:50 I found some AT commands that did work. The one on your wiki does not work.
[url=http://it.emcelettronica.com/files/Manual%28EN%29.pdf]http://it.emcelettronica.com/files/Manual%28EN%29.pdf[/url]
What commands should I send to it in AT mode? To get this to work?
The Crusher
The Crusher
The Crusher 2012-10-17 20:17:54 Last time I was in AT mode, with right baud rate and that stuff, I only got OK as a return when writing AT. If I tried to write anything else like written on your wiki, i just got Error(0) in return.
The Crusher
The Crusher
The Crusher 2012-10-17 20:06:43 It could be some config error. You might want to go into AT mode and see if you can make some changes to the configuration. Please double check your BPs
Hector
Hector 2012-10-17 20:06:43 It could be some config error. You might want to go into AT mode and see if you can make some changes to the configuration. Please double check your BPs
Hector
Hector 2012-10-17 00:27:28 Hi hector,
I have conected it to a bluetooth mate gold from sparkfun, but that was when the bluetooth bee was on my computer. I could only connect, but not send any data.
Also, in AT mode, i only get OK on writing AT, nothing else.
The Crusher
The Crusher 2012-10-17 00:27:28 Hi hector,
The Crusher
The Crusher 2012-10-16 19:57:54 Hi Crusher,
Have you tried paring the bluetooth bee with a PC first? Don't forget that these modules come with a default password 1234.
Please try with other devices to make sure the bee is able to connect to something else, as well do the same with your cell phone.
Let me know if you were successful at connecting
Hector
Hector 2012-10-16 19:57:54 Hi Crusher,
Hector
Hector 2012-10-12 12:52:31 Hi,
The Crusher
The Crusher
