Fez Panda II with DF-BluetoothV3 Bluetooth module
userHead Account cancelled 2012-11-24 01:03:50 3629 Views1 Replies
I have a Fez Panda II that i would like to use with a Bluetooth module. I have found this:
[url=http://www.dfrobot.com/index.php?route=product/product&path=45_79&product_id=360#.UK87tYcsBgh]http://www.dfrobot.com/index.php?route=product/product&path=45_79&product_id=360#.UK87tYcsBgh[/url]
Does this work directly with Fez Panda II or do I need some sort of sheild or expansion?
2012-11-27 02:03:07 Hi,
You can wire the TTL pins of the Bluetooth V3 to your Fez Panda. It can work!
The IO expansion shield V5 for Arduino could make it easier for your to extend the bluetooth module for your Panda II without wiring.
[url=https://www.dfrobot.com/index.php?route=product/product&filter_name=io%20expansion%20shield&product_id=264#.ULM8-E09ha0]https://www.dfrobot.com/index.php?route=product/product&filter_name=io%20expansion%20shield&product_id=264#.ULM8-E09ha0[/url]
Regards,
Lauren
userHeadPic Lauren
