Too much text sent in SMS with GPS/GPRS/GSM Shield v3
userHead alnath 2013-04-28 13:28:10 3230 Views1 Replies
Hello :)
After several tries, I finally succeeded in sending a SMS with the new shield described here : [url=http://www.dfrobot.com/wiki/index.php/GPS/GPRS/GSM_Module_V3.0_%28SKU:TEL0051%29]http://www.dfrobot.com/wiki/index.php/GPS/GPRS/GSM_Module_V3.0_%28SKU:TEL0051%29[/url]
The sms is sent OK, but it contains everything that I wrote before the SMS text, including the pin code etc... that means that my correspondant (me, actually, with a mobile and another SIM) receives everything that was in the coolterm window ! What can I do to send only the text I want to send ?
Thanks a lot for your help,
I used the 1st sketch of the page, quoted here, and coolterm to send At commands :
[code]
// Product name: GPS/GPRS/GSM Module V3.0
// # Product SKU : TEL0051
// # Version : 0.1
// # Description:
// # The sketch for driving the gsm mode via the USB interface
// # Steps:
// # 1. Turn the S1 switch to the Prog(right side)
// # 2. Turn the S2 switch to the USB side(left side)
// # 3. Take off the GSM/GPS jumper caps from the Uart select
// # 4. Upload the sketch to the Arduino board(Make sure turn off other Serial monitor )
// # 5. Turn the S1 switch to the comm(left side)
// # 7. RST the board
// # wiki link- http://www.dfrobot.com/wiki/index.php/GPS/GPRS/GSM_Module_V3.0_(SKU:TEL0051)
//Init the driver pins for GSM function
pinMode(3,OUTPUT);
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
//Output GSM Timing
digitalWrite(5,HIGH);
delay(1500);
digitalWrite(5,LOW);
digitalWrite(3,HIGH);//disable GSM TX?RX
digitalWrite(4,HIGH);//disable GPS TX?RX
[/code]
2013-04-29 08:08:22 OK, never mind, when I use the same AT commands in a sketch, everything works well, the sms is OK userHeadPic alnath
