FlyMaple
userHead muawijhe 2013-03-13 09:57:25 3478 Views3 Replies
I would like to know if it is possible to use the GPS shield with the FlyMaple. In particular:
- is the UART of the GPS compatible with the FlyMaple associated pin (in terms of voltage?)
- it is possible to have a FlyMaple which can be mounted on top of the GPS shield (to let free the connector for RC/Servo)?? This is also a suggestion for the product... (make the FlyMaple a shield-like PCB)
Finally, can you suggest me a radio module (not bluetooth or wireless) which can be used with FlyMaple (again voltage issues).
Thanks in advance for the help,
have a good day,
Vincenzo
2013-05-07 20:08:49 @muawijhe
Sorry for reply late, the Jst kits 2.0mm fits ;)
[url=https://www.dfrobot.com/index.php?route=product/product&filter_name=jst&product_id=836#.UYh-JrX-HN4]https://www.dfrobot.com/index.php?route=product/product&filter_name=jst&product_id=836#.UYh-JrX-HN4[/url]
BEST
userHeadPic Phoebe
2013-05-04 14:45:55 Dear Phobe,
thanks for the reply.
Could you tell me which of the JST kits (2.0mm or 2.54mm) fits the FlyMaple onboard Connectors?
userHeadPic muawijhe
2013-03-14 02:03:12 Hi
Do you use the this GPS shield? If yes,then:
[url=https://www.dfrobot.com/index.php?route=product/product&filter_name=gps&product_id=481#.UUBDRBynr58]https://www.dfrobot.com/index.php?route=product/product&filter_name=gps&product_id=481#.UUBDRBynr58[/url]
1)According to the schematic of  GPS shield ,it works in 3.3V, so it is compatible with the FlyMaple(i think any GPS module which works in 3.3V can compatible with the flymaple)
2)**, good idea ;D  Cool~~,may be we will improve it in the next version, thank you for your suggestion ;)
You can add some stackable headers between the two boards,then the GPS shield can be mounted on top of the Flymaple , and you can use the connector for RC/Servo also ;)
3) Do you have some requirements about the radio module? Like RF module?
userHeadPic Phoebe
