About the sensor SEN0114 output
Account cancelled 2013-04-05 02:58:57 5582 Views1 Replies Hello everyone,
I'm working on a project where i have to use a sensor linked to a pic (18f24k22).
I'm realy interesting in buying your sensor SEN0114, the problem is, i absolutely dont find any information about the tension (V) leaving this sensor (output).
Indeed, i need the differents values of this tension in fonction of the humidity.
Thanks to this values, it will be possible for me to config my PIC.
I realy hope you could help me.
Thanks a lot
Thanks a lot
2013-04-07 18:21:04 Hi
The NO.1 pin of the 3pin-connector on the sensor board is the signal ( analog output ) , you can read the analog output data from it via your pic.
Phoebe
Phoebe
