romeo v2 not recognited [solved]
infobarque 2013-07-04 06:09:27 2660 Views1 Replies Hi,
since few minutes, my romeo v2 is not recognited on linux.
before it was recognized as /dev/ACM0
Have you any idea why?
thank's
EDIT
solved
thank's
EDIT
solved
2013-07-05 19:06:16 Hi,
if you 'tail' system log you can easily see the reassigning of Romeo V2 after a short delay when it is plugged in. I suggest you keep that in mind, as to avoid getting annoying errors on Arduino IDE. A simple way to do it, is take a look at the LEDs on the romeo board, when it is done flashing, the device will be assigned to the right port /dev/ACMx and you can upload fine..
Cheers^^
Jose
Cheers^^
Jose
