6DOF Arduino Shield Trouble with xbee
userHead Marc.H 2013-07-10 21:50:54 4721 Views3 Replies
Hie,
I have bought 2 6DOF Shield for arduino. With the both shield I have the same trouble : Without Xbee module, all is right, my project is functional (it's a pendulum bot). But when i put a xbee module all the arduino go down. All seems to be freeze.
I try the two shield on a DFRDUINO UNO V3 and on a Arduino UNO R3 with the same result.
Have you an idea about what happen ?
With only the shield and an arduino with an empty sketch give the same result ....
Best regards
Marc H
2013-07-11 22:46:32 Hey Marc,
Send an email to Technical support at
[email protected]
Or open a ticket in the forums.
cheers
userHeadPic Jose
2013-07-11 04:05:46 I try to be more précis :
If the xbee module is not plug in : All is alright
When I put the Xbee module, on the shield, On Led is on, ASSOC Led is not off and not on, in the middle
                                            on the arduino, (with the blink sketch) : Green led stay on and orange LED stay on
Is it better ?
userHeadPic Marc.H
2013-07-11 03:49:52 Hi Marc,
Does the power LED turn off as well?
[quote="Marc.H"]
[/quote]
So independently of the Xbee is it freeze or not? not sure what you mean..
Rgds,
Jose
userHeadPic Jose
