GSM Module V3 shuts down after network registration
userHead omercnet 2013-07-14 23:28:53 2981 Views2 Replies
I'm having a lot of trouble using the GSM module (V3)..
I've tried different SIMs from different carriers, but the module stops communicating (STAT & NET lights turn off) after it registers to the network..
I've used the default sketch to communicate over serial:
[code]
//Init the driver pins for GSM function
pinMode(3,OUTPUT);
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
//Output GSM Timing
digitalWrite(5,HIGH);
delay(1500);
digitalWrite(5,LOW);
digitalWrite(3,HIGH);//disable GSM TX?RX
digitalWrite(4,HIGH);//disable GPS TX?RX
[/code]
and this is the result I get:
[code]
IIII????
Sending AT query..
AT
OK
Successful response for AT query..
+CFUN: 1
+CPIN: READY
AT+CGMM
SIMCOM_SIM908
OK
Model Number : SIMCOM_SIM908
+CREG: 2
AT+CGMI
SIMCOM_Ltd
OK
Manufacturer : SIMCOM_Ltd
+CGREG: 0
+CREG: 1,"10CC","9043"
[/code]
and then the module shuts down, no NET or STAT leds, just PWR, and I can't communicate over console..
all I can do is reset..
any ideas?
2013-07-15 20:39:10 [quote="omercnet"]
Solved by connecting to external power source...
I guess USB can't power this module alone...
[/quote]
Hi Omercnet,
This is normal behavior, Its written on the wiki.
I often forget when I play with mine and it gives me quite some trouble  ::)
Cheers!
userHeadPic Jose
2013-07-15 03:25:54 Solved by connecting to external power source...
userHeadPic omercnet
