(AT+NCTCP) and how to send data via tcp in wifi shield v2.2
potato 2013-11-22 23:12:47 7440 Views19 Replies hello, good evening
I'm doing Station Mode and Multi Sockets example 10.3.1 in the manual
[code]
AT
[OK]
ATE0
[OK]
at+XDUM=0
[OK]
at+bdata=1
[ok]
at+wd
[ok]
at+ndhcp=1
[ok]
at+wwpa = potatohead
[ok]
at+wa=randy
IP SUBNET Gateway
192.168.1.103 255.255.255.0 192.168.1.1
[ok]
at+nctcp=192.168.1.105,5000
[ERROR]
[/code]
I already tried many different last digit in the IP, but all i got was the [error] response
how can I use at+nctcp ? where did I goes wrong?
thank you
[code]
AT
[OK]
ATE0
[OK]
at+XDUM=0
[OK]
at+bdata=1
[ok]
at+wd
[ok]
at+ndhcp=1
[ok]
[ok]
at+wa=randy
IP SUBNET Gateway
[ok]
[ERROR]
[/code]
thank you
2013-12-07 03:45:38 the library is still in my pc jose, still under development.
but, soon, it will finish.
i'll surely share when i finish working on it :)
potato
potato 2013-12-07 03:45:38 the library is still in my pc jose, still under development.
potato
potato 2013-12-07 02:27:09 Potato,
this is looking great! any idea where to find this library so I can give it a go ?
Jose
Jose 2013-12-07 02:27:09 Potato,
Jose
Jose 2013-12-07 02:01:43 I already can send data bro,
[code]#include <SoftwareSerial.h>
#include <WizFiRandy.h>
byte *payload;
byte connFlagWillRetain;
byte connFlagCleanSession;
byte pubDupFlag;
byte pubRetain;
unsigned int pubMsgId;
unsigned int mqttPacketLength;
unsigned int mgttResponseLength;
char modemImei[16];
char ip[16];
// put your setup code here, to run once:
connFlagWillRetain = 0;
connFlagCleanSession = 1;
pubDupFlag = 0;
pubRetain = 0;
pubMsgId = 10;
Serial.begin(115200);
Serial.println("+++");
Serial.flush();
delay(500);
checkwizfistatus(mainBuffer, 5000);
delay(500);
wizfiate0(mainBuffer, 5000);
delay(500);
wizfixdum(mainBuffer, 5000);
delay(500);
wizfibdata(mainBuffer, 5000);
delay(500);
wizfindhcp(mainBuffer, 5000);
delay(500);
wizfisetstatic(mainBuffer, 5000);
delay(10000);
wizfiwwpa(mainBuffer, 5000);
delay(500);
wizfisetup(mainBuffer, 5000);
delay(15000);
wizficonnectserversetup(mainBuffer, 5000); //this is at+nctcp=ip,port
Serial.flush();
delay(100);
// put your main code here, to run repeatedly:
mqttPacketLength = buildMqttConnectPacket(mainBuffer, connFlagWillRetain, MQTTQOS0, connFlagCleanSession);
Serial.print("\x1B" "S0"); //header for sending data
Serial.println(mqttPacketLength);
Serial.print("\x1B" "E"); //header for sending data
mqttPacketLength = generatePayload(modemImei, "3ph");
payload = (byte*)malloc(mqttPacketLength+1);
memset(payload, 0, mqttPacketLength+1);
strcpy((char*)payload, (char*)mainBuffer);
mqttPacketLength = buildMqttPublishPacket(mainBuffer, pubDupFlag, MQTTQOS0, pubRetain, pubMsgId, payload, strlen((char*)payload));
free(payload);
[/code]
so, for the conclusion is, i just need to add \x1BS0 for beginning of the message and add \x1BE for the end of the message
soon, this module can support mqtt protocol with my library
Thx for your support bro ^^
potato
byte *payload;
byte pubDupFlag;
byte pubRetain;
char modemImei[16];
char ip[16];
pubDupFlag = 0;
pubRetain = 0;
pubMsgId = 10;
Serial.flush();
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(10000);
delay(500);
delay(15000);
Serial.flush();
delay(100);
free(payload);
[/code]
potato 2013-12-07 02:01:43 I already can send data bro,
byte *payload;
byte pubDupFlag;
byte pubRetain;
char modemImei[16];
char ip[16];
pubDupFlag = 0;
pubRetain = 0;
pubMsgId = 10;
Serial.flush();
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(10000);
delay(500);
delay(15000);
Serial.flush();
delay(100);
free(payload);
[/code]
potato
byte *payload;
byte pubDupFlag;
byte pubRetain;
char modemImei[16];
char ip[16];
pubDupFlag = 0;
pubRetain = 0;
pubMsgId = 10;
Serial.flush();
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(10000);
delay(500);
delay(15000);
Serial.flush();
delay(100);
free(payload);
[/code]
potato 2013-12-07 01:18:16 I think after you do at+nctcp=x,x you want to go back to serial mode to let Arduino try to send data. Then trigger back with escape sequence to get AT commands and close the connection when done.
Take a look at this post for instance,
[url=https://www.dfrobot.com/forum/index.php?topic=494.msg2252#msg2252]https://www.dfrobot.com/forum/index.php?topic=494.msg2252#msg2252[/url]
If ATO is giving you some trouble, try ata. however, I am not sure if ata would close the nctcp connection since it probably restarts or reconnects the wireless.
I'm still stuck with my board trying to get the +++ and any of all the escape sequences options working. I did not have much time to test it but i'll try a bit more later. I've got a little mess on my board with firmware upgrade tests and so on...
Let me know how it goes so I can try it
Jose
Jose 2013-12-07 01:18:16 I think after you do at+nctcp=x,x you want to go back to serial mode to let Arduino try to send data. Then trigger back with escape sequence to get AT commands and close the connection when done.
Jose
Jose 2013-12-05 01:51:27 actually, all i did is just write at+nctcp= ip address, port 1883.
and I got [connect 0] response,
if i try to send data with or without escape sequence, all i got is [error invalid input] response.
so, how do you think about this jose?
potato
potato 2013-12-05 01:51:27 actually, all i did is just write at+nctcp= ip address, port 1883.
potato
potato 2013-12-04 23:45:16 Hey Potato,
I'm trying with an old wifi shield v2.1 at+nctcp without much luck. Did you enable the escape sequence manually? or just left it as defaulted? GPIO trigger and software escape sequence on mine is not behaving well.
Anyway, my guess is just as you said. With the Wifi bee I did it with escape sequence as well. I suppose you just open the connection with nctcp and start outputting arduino's data.
Jose
Jose 2013-12-04 23:45:16 Hey Potato,
Jose
Jose 2013-12-04 04:06:11 Ok, so I already can do at+nctcp,
the next problem is, how can I send data via tcp?
is it using escape sequence? if so, please tell me how, I already tried the manual but didn't work.
potato
potato 2013-12-04 04:06:11 Ok, so I already can do at+nctcp,
potato
potato 2013-11-23 01:23:36 i input at+nctcp before at+wwpa&at+wa
and
[DISASSOCIATED]
is the respond i got
potato
and
[DISASSOCIATED]
and
[DISASSOCIATED]
potato
and
[DISASSOCIATED]
potato 2013-11-23 00:12:30 Hello potato!
I'm still looking into the other thing, but try
at+nctcp
Before doing
at+wa
Jose
at+nctcp
Before doing
at+wa
Jose 2013-11-23 00:12:30 Hello potato!
at+nctcp
Before doing
at+wa
Jose
at+nctcp
Before doing
at+wa
Jose 2013-11-22 23:12:47 hello, good evening
[code]
AT
[OK]
ATE0
[OK]
at+XDUM=0
[OK]
at+bdata=1
[ok]
at+wd
[ok]
at+ndhcp=1
[ok]
[ok]
at+wa=randy
IP SUBNET Gateway
[ok]
[ERROR]
[/code]
thank you
potato
[code]
AT
[OK]
ATE0
[OK]
at+XDUM=0
[OK]
at+bdata=1
[ok]
at+wd
[ok]
at+ndhcp=1
[ok]
[ok]
at+wa=randy
IP SUBNET Gateway
[ok]
[ERROR]
[/code]
thank you
potato
