Beetle and beetle shield
userHead cvd 2014-03-04 03:40:22 4168 Views6 Replies
Hi. I´m new on this
Please can you say me what cain of servo can I use with the beetle shield ? Can I use a 360 degrees servo to use like dc motor with the beetle shield ?
In the beetle shield wiki not say nothing about the maximum A for the servo or what cain of servo use with this shield.
Also , how can i connect other arduino shileds to the Beetle board ?
Thank
Carlos
2014-03-06 03:25:43 Them will be used with easy Vr ?
But to add a pin heater you need to solder the wires first on the board , no? I see no other way.
Carlos
userHeadPic cvd
2014-03-06 02:40:35 It is better to add a pin header.
Beetle are using a Leonardo chip,
So that TX and RX should be Serial1.
userHeadPic Grey.CC
2014-03-06 01:43:05 I think serial , EasyVR I think use serial.
I see that need to solder 4 wired to the bottom part of the board before solder to the shield to put out  the TX , RX , SCL and SDA.
Carlos
userHeadPic cvd
2014-03-05 18:56:04 Yes, you could use two 360 degrees servo.
For the signal pin, I/O pins only could stand 40~50 ma.
A voice recognition shield? IIC communication protocol? or serial  one?
userHeadPic Grey.CC
2014-03-05 02:49:15 Could i understand that i can use two 360degress servo?what are the maximun that the shield support , 600mA?
I know that there is not space to plug directly other shield, but , can I connect (wired) other shield like for example a voice recognition shield?
Thank
Carlos
userHeadPic cvd
2014-03-04 23:23:45 Hello Carios,
Beetle only has 6 pins: D9~D11 and A0~A2
It could drive the servo.
What is your mean of other shield?
I don't think it could plug other big shield on it.
userHeadPic Grey.CC
