Moisture Sensor (SKU:SEN0114) Units?
anonymous_fz 2012-10-17 07:46:18 5946 Views5 Replies In this page here:
[url=http://www.dfrobot.com/wiki/index.php/Moisture_Sensor_(SKU:SEN0114)]http://www.dfrobot.com/wiki/index.php/Moisture_Sensor_(SKU:SEN0114)[/url]
The value range is mentioned...
Value range:
1. 0 ~300 : dry soil
2. 300~700 : humid soil
3. 700~950 : in water
What are the units for measuring this value range? like 0 ~300 what? what is the measurement unit?
Value range:
2014-03-12 19:35:20 Yes, it is linear.
You could check the analog sensor value
# 0 ~300 dry soil
# 300~700 humid soil
# 700~950 in water
It is only the sensor value, you need transform it into Humidity
Add this line:
dat=analogRead(0); //humidity max connected to A0
dat=map(dat, 0, 1023, 0, 100);
The dat will be the real humidity.
Grey.CC
# 0 ~300 dry soil
# 700~950 in water
Add this line:
Grey.CC 2014-03-12 18:25:16 ? have bought Moisture Sensor (SKU:SEN0114) and i would like to ask you if this sensor is linear?
I sent data from sensor by an xbee in ASCII to arduino, and convert it to demical. I would like to know if sensor is linear? when i have 0% humidity is dry solid and when i have 100% is water?
Louks
Louks 2012-10-18 17:23:39 its just a sensor, it doesn't need to be programmed. That is the analog range of values it gives.
The sample code provided will give you those readings...
Hector
Hector 2012-10-18 05:36:45 So the soil moisture sensor has to be programmed with the given ranges? or is it already programmed like that or is the program written in the sample code of the AFWS controller?
anonymous_fz
anonymous_fz 2012-10-17 16:47:52 There is no units for this, its just a range of values. from 0~1000
That is why we broke it down to different value ranges.
Hector
Hector
