Which shield to use ?!?!?!?!?!
userHead MMAB 2014-04-06 23:11:33 3673 Views3 Replies
Hi there,
I have an Arduino Mega 2560, and i want to place it in my car along with some limit switch's and some sensors.
The thing is i want a shield that would send the location of my car to a website DATABASE that i build. i also want it to send the information that the SENSORS will gather from the car status.
I am not sure which shield is best to use, but i need it to send these information and then the database will collect them and add them to their specified fields.
Thanks :D
2014-04-13 06:06:30 Hi there
I got the GPS/GPRS/GSM Module V3.0 shield and i was able to send messages to my phone. However, when i want to get the GPS location of the board, i't wont show it.
I used the code offered in your wiki titled "How to drive the GPS Mode via Arduino board", then i connected my Arduino MEGA 2560 board to the USB cable and a power supply of 9V.
the board and shield LED's flash's yet nothing happens, i even tried to go outside and try to get a good signal, still nothing. I even have alot of  credit in the SIM card that i am using.
here is an image of the output i got.
Here is the output itself
[font=Verdana]AT[/font][font=Verdana]AT+CGPSPWR=1AT+CGPSRST=1$GPGGA statement information: UTC:ovfLat:ovfDir:,Lon:ovfDir:,Alt:ovf  UTC:144015.09Lat:ovfDir:,Lon:ovfDir:,Alt:ovf  UTC:144021.09Lat:ovfDir:,Lon:ovfDir:,Alt:ovf
please help what should i do?!?!
Thanks :D [/font]
userHeadPic MMAB
2014-04-11 00:59:01 I think it is best to use the gps/gprs/gsm shield
because i am not going to need a real time tracking
Thanks BTW realy helped :D
userHeadPic MMAB
2014-04-09 22:46:56 Welcome MMAB!
What about this:
[url=https://www.dfrobot.com/index.php?route=product/product&filter_name=gps&product_id=673]https://www.dfrobot.com/index.php?route=product/product&filter_name=gps&product_id=673[/url]
You want to send it real time?
As for the car status, you can look up this product OBD:
[url=https://www.dfrobot.com/index.php?route=product/search&filter_name=obd]https://www.dfrobot.com/index.php?route=product/search&filter_name=obd[/url]
If not, you can use a SD card and store the data and upload it later to the website. But the gprs module seems to be a nice choice for uploading data. There is an example on Git on uploading to a website.
Cheers!
userHeadPic Jose
