Relay Shield for Arduino V2.1 with Arduino Ethernet
userHead aut 2014-07-01 12:05:04 7906 Views8 Replies
I recently bought 4 relay shields. I was wondering what is the maximum number of relay shields that can be stacked?
I understand that the Ethernet module reserves Digital pin 10/11/12/13. This leaves me with 9 pins. Is there anyway to control the 4 relay shields with the Arduino Ethernet?
Thanks!
2014-07-08 01:24:27 Yeah, it should be compatible with Mega.
But I am not sure whether the power supply could support so many relays at the same time.
The jumper caps are ph2.0, it is a little small for ordinary jumper cable. What is about soldering?
userHeadPic Grey.CC
2014-07-05 16:01:50 Two more questions.  ;D
1) Is the 'Relay Shield for Arduino V2.1' compatible with Mega?
2) Where can I find the jumper wires? The 4 jumper caps seems to be smaller than the standard 0.1" female headers
Thanks again!
userHeadPic aut
2014-07-04 21:25:24 Mega will definitely help. Mega often means more available PINS  ;D
You will need a pack of jumper wires as well
userHeadPic Jose
2014-07-04 08:07:20 Sorry for the confusion. I meant 56 switches with 14 relay shields for the second part of my project.
userHeadPic aut
2014-07-03 23:06:07 14 should be OK, 8 Digital pins + 6 Analog pins should be enough in your project. userHeadPic Grey.CC
2014-07-03 11:40:41 Hello,
Thanks for the quick response. I am using the relays to control a bunch of switches over the internet. I will eventually need 14 relay shields. For the first part of the my project, I am trying out with only 3 relay shields.
What do you guys think is the better way? Get more Arduino boards and control the relays separately. Or to use Arduino Mega?
Thanks again
userHeadPic aut
2014-07-02 00:01:02 You can use analog pins as digital pins, so you should be able to stack up a few shields. With the right wiring on the jumpers selector..  If you don't need the serial port, and need the extra pins should not be a big deal to use them. But you can't expect any Serial.print feedback like that. userHeadPic Jose
2014-07-01 19:15:34 Welcome Aut,
As Ethernet board has occupied D10~13, so the empty pin should be D2~9 (It is not a good idea to use D1&D0, they are Serial port), and Analog 0~5. So it will be 14 pins in all. So the maximum could be 3.
How many relays do you want to control?
There are 4 jumper caps on the shield. they select 4 digital IO pin for control(Default digital 2,7,8,10) , you could take them off, and connect other pins to relay connect pins.
Do you want to make remote control system?
userHeadPic Grey.CC
