FIT0137 - 7.4V Lipo Battery Charging Questions, Please Respond
Account cancelled 2014-07-22 19:11:13 2323 Views1 Replies Guys,
I need some help with the following questions:
1) Can i charge the battery while plug in a bot, basically connecting the charger in parallel with the battery ?
2) I have a 12V / 5A charger, can i use it ?
3) If i use the 12V/5A what is the charging time needed to full charge, assuming the battery is low but not full discharged. Any formula or rule to calculate the charging time based in the V And/OR Amps ?
4) This kind of discharge, and charge is ok ? Or is prone to create battery memory problems ?
I would like to implement a robot's charging station, the robot will seek the station when the battery is low (assuming it's possible to monitor the battery Volts, hopefully a sequential drop in Volts ), while in the station (if point 1 is possible), the robot will wait X/Constant time recharging.
Is this feasible ?
Any feedback will be appreciated.
Tiago
Is this feasible ?
Tiago
2014-08-22 11:18:08 you will need a lipo charger... on most lipo chargers you can set the amp... it is normal to charge a lipo with 1c that means that if you have a 2200mAh (2.2Ah) that will take 1 hour at 2.2Amp (if fully empty, which it should NEVER be) the battery is full when each cell is at 4.2v and may only be discharged to around 3,3v
sth0r
sth0r
