Can't program an X-Board v2 using FTDI Basic Breakout
userHead kobalt.systems 2015-01-13 17:04:58 3336 Views2 Replies
Hi all,
I'm fairly new to Arduino but know enough now to be dangerous ;)
I've been working on a basic project using the X-board v2 (SKU:DFR0162) and the Basic Breakout FTDI programmer (SKU: DFR0065).
I have been using 1.5.8 IDE on windows 8.1 (disabled driver signing etc) and have had no trouble with uploading various sketches using the above right up until yesterday.
Now, literally overnight, I get "avrdude: Error: Could not find USBtiny device (0x1781/0xc9f)" using USBtinyISP or avrdude: usbdev_open(): did not find any USB device "usb" when using AVRISP mkII (default) when uploading a sketch.
I have attempted: rebooting, unplugging/plugging; swapping USB cables; changed computers (same OS); removing all sensors from board; changed IDE to 1.0.6; uploading an empty sketch; bypassing built in headers on the breakout board; checked all solder joints are clean; changed all programmers in IDE (even though I hadn't changed beforehand).
What I see: the L light is flashing very fast and almost looks dim; the last sketch seems to be running (I can see the x-board on the network); COM ports seem OK on PC/s (get the same result on two separate computers); voltage is set correctly (5v) on the FTDI.
Remember, no changes were made between when it worked and when it didn't.
So, this is where my knowledge drops off a lot. Can the bootloader be corrupt? What are the best programmer settings for the FTDI programmer? Is the board bricked?
Really appreciate any help.
Cheers
Nick
2015-01-14 12:39:16 Hey Grey,
Thanks for your response.
Guess what, I figured it out and it was a PEBKAC error...(Problem Exists Between Keyboard and Carpet).
I was using the wrong keyboard shortcut for the upload CTRL+SHIFT+U instead of CTRL+U  :-[ :-[ :-[ :-[ :-[
That was a facepalm moment
All is well and got the test running fine....
userHeadPic kobalt.systems
2015-01-14 05:49:26 Aha~
Which board did you select in the Arduino IDE? UNO or Amegat328?
There are a lot of 328 bootloader in the IDE. it will easy be mixed.
userHeadPic Grey.CC
