How to use Wido
userHead Account cancelled 2015-01-16 23:38:01 2089 Views2 Replies
Hi, anyone can give me tips and trick about uploading sketch on Wido
I have some problem with Wido, the sketch is done for uploading, but when i test on serial monitor, i can't communicate with Wido (i use same example on library that given on dfRobotWIKI) with 115200 baudrate on serial monitor
2015-01-20 05:19:23 Buildtest?
Try to add a delay in the setup.
Wido is leonardo chip. It will keep working, after you upload the the sketch.
If you add a delay, it will show the network configuration in the serial port.
userHeadPic Grey.CC
2015-01-19 14:53:47 Hi Siwilis, the WiDo is a bit of a nightmare to get running (I'm pretty unhappy with mine).
Which sketch are you trying to run?
userHeadPic Rozz
