RAM
Power Supply
Aluminum Case
HDMI
SD Card
Add-on
Quantity
Get everything you need to unleash the full potential of your Raspberry Pi 4! This comprehensive kit includes a Raspberry Pi 4 Model B board (available in 2GB, 4GB, or 8GB variants), a high-quality USB power supply, a durable aluminum case with excellent cooling performance, a 4K Micro HDMI cable, and a reliable MicroSD memory card. Perfect for beginners and advanced makers alike—just Plug & Play to get started.
Raspberry Pi 4 Model B (2GB / 4GB / 8GB)
Equipped with a high-performance 64-bit quad-core processor, the Raspberry Pi 4B is ideal for projects requiring speed and versatility. Key features include:
4K HDMI / Mini HDMI to Micro HDMI Cable
This micro-HDMI cable is designed specifically for the Raspberry Pi 4B, offering:
5V@3A USB Power Supply (US Standard / EU Standard)
This reliable power adapter ensures optimal performance for your Raspberry Pi 4:
Case
Why Choose Our Case?
We've selected 2 high-quality aluminum cases with a powerful cooling effect in the kit.
Our Aluminum Alloy Case:
The aluminum alloy material is hard; easy to install.; double cooling effect with fan & heatsink; delicate appearance; not easy to rust.
Other Acrylic Case:
The plastic material is thin and fragile. The Acrylic case is hard to assemble. The fan is at a lower speed and hard to cool. The fan is easy to make a lot of noise; Easy oxidized and looks ugly.
How to Choose the Case?
If you are looking for value for money, we recommend you choose the Aluminum Case for Raspberry Pi 4 (with Heatsink & Fan), it is perfect for novices.
If you want a better look and a better cooling effect, we recommend you choose the metal case for the Raspberry Pi 4B (Dual fans). This case can improve your user experience.
This aluminum-made case features a hollow design, delicate appearance, and high hardness. The aluminum material makes it not easy to rust and more conducive to heat dissipation.
Metal Case for Raspberry Pi 4B (Dual fans)
With Cut-out Design Simple and Aesthetic; Open design, avoid signal isolation, no influence on Wi-Fi, and Bluetooth; Dual fans, advance the cooling efficiency.
Sandisk MicroSD Memory Card (32GB / 64GB / 128GB)
This high-speed memory card is perfect for running your Raspberry Pi:
Optional Add-Ons
DSI Touchscreen Displays (5" / 7")
High-resolution capacitive touchscreens that support Raspberry Pi DSI interface:
A compact and driver-free USB camera for Raspberry Pi and NVIDIA Jetson Nano:
Development environment setup
Basic Settings
Optional Accessories:
