Solar Panel (9v 600mA)
$5.50
SKU: FIT0330
Compact, high-output solar panel with 9V peak power, 220mA current, and waterproof design, ideal for powering or recharging devices. Suitable for various applications.
Purchase this product and earn 55 reward points, which are tied to VIP membership program. Learn More >
DFRobot 9V 600mA Solar Panel provides a compact renewable power source designed for embedded electronics, outdoor prototypes, and portable energy systems. This photovoltaic power module delivers a peak output of approximately 9V at 600mA, suitable for direct powering of low‑power electronics or integration into battery‑charging circuits. The durable solar energy board uses an ultra‑white glass lamination process to improve light transmission while protecting internal cells from moisture and environmental exposure. Reliable DC output and simple wiring make this clean‑energy panel practical for robotics experiments, environmental monitoring nodes, and Arduino-based energy harvesting projects.
Note: The above refers to the electrical performance parameters measured under standard test conditions, namely: light intensity 1000W / ㎡, spectrum AM1.5, cell temperature 25 ℃
Stable Photovoltaic Power Output
This compact solar generating unit provides a typical working voltage of 9V with a maximum operating current of 0.6A, delivering up to 5.4W of power under optimal lighting conditions. Such electrical characteristics allow the photovoltaic board to supply energy for small controllers, battery charging circuits, and low‑power embedded electronics. Multiple panels may also be connected in series to support higher‑voltage charging systems such as 12V battery setups used in portable or remote installations.
Durable Laminated Glass Construction
An ultra‑white glass lamination layer enhances light transmission while forming a protective waterproof barrier over the solar cells. This structural design improves conversion efficiency while increasing durability for outdoor operation. The laminated photovoltaic surface helps resist moisture, dust, and environmental wear, making the solar energy module suitable for long‑term deployment in field electronics, transportation infrastructure prototypes, and remote sensing stations.
Simple Integration for Prototyping Systems
Separate aluminum output wires on the rear side allow straightforward electrical connection with charging controllers, power regulators, or embedded development boards. This renewable power module integrates easily with robotics platforms, IoT prototypes, and educational electronics experiments. Compact dimensions also support portable installations where stable off‑grid energy generation is required without adding significant size or weight.
Typical implementations include solar‑powered robotics, communication equipment, transportation electronics, and renewable energy demonstrations. The photovoltaic module also supports rapid prototyping for environmental monitoring devices, outdoor sensor nodes, and STEM learning projects focused on sustainable power generation.
  • Peak output around 9V at 600mA
  • Maximum power output up to 5.4W under standard test conditions
  • Ultra‑white laminated glass surface improves light transmission and durability
  • Water‑resistant panel structure suitable for outdoor environments
  • Rear aluminum output wires for convenient electrical connection
  • Multiple panels can be connected in series for higher‑voltage charging systems
  • Compact form factor suitable for portable and embedded energy projects
  • Solar power generation for small electronic systems
  • Transport sector energy support prototypes
  • Communication and remote electronic equipment
  • Portable renewable energy demonstrations
  • Environmental monitoring and outdoor sensor nodes
  • Working Voltage: 9V
  • Maximum Working Current: 0.6A
  • Open Circuit Voltage: 10.8V
  • Short Circuit Current: 0.825A
  • Power: 5.4W
  • Storage Temperature: -20°C~60°C
  • Size: 265*175mm
  • Solar Panel (9V 600mA) x1
