Solar Panel (9v 600mA)
$5.50
SKU: FIT0330
Compact, high-output solar panel with 9V peak power, 220mA current, and waterproof design, ideal for powering or recharging devices. Suitable for various applications.
Purchase this product and earn 55 reward points, which are tied to VIP membership program. Learn More >
Need a clean energy source for your project? Check out this compact, high quality, high output endurable solar panel. The peak power output is around 9V at 600mA. Can also be used in series to work as a recharger for 12V batteries.
Ultra-white glass lamination process provides an efficient and waterproof surface for the panel. The back of the panel has separate aluminum wires.
Note: The above refers to the electrical performance parameters measured under standard test conditions, namely: light intensity 1000W / ㎡, spectrum AM1.5, cell temperature 25 ℃
  • Solar Powering
  • Transport sector
  • Communication/communications
  • Working Voltage: 9V
  • Maximum Working Current: 0.6A
  • Open Circuit Voltage: 10.8V
  • Short Circuit Current: 0.825A
  • Power: 5.4W
  • Storage Temperature: -20°C~60°C
  • Size: 265*175mm
  • Solar Panel (9v 600mA)    x1
