Need a clean energy source for your project? Check out this compact, high quality, high output endurable solar panel. The peak power output is around 9V at 600mA. Can also be used in series to work as a recharger for 12V batteries.
Ultra-white glass lamination process provides an efficient and waterproof surface for the panel. The back of the panel has separate aluminum wires.
Note: The above refers to the electrical performance parameters measured under standard test conditions, namely: light intensity 1000W / ㎡, spectrum AM1.5, cell temperature 25 ℃
